some new to me bits arrived this week , although there are more on order from the uk (things like el cheapo brake pads for both bikes , a sump oil window and some preparatory bits for gertys output shaft pull down , later this year ...after this project gets on the road )
from grahame jays , kbikebeemerbits with many thanks
as they arrived
afterwards that day , now cleaned up , ie washed , and prepared for paint with plastic primer , etch primer etc , the Charlie treatment ,
all in a hurry as we are suffering snow fall predictions tomorrow .....
a quick dash outside to the little wood shed ( prepped for painting purpose , ie sheets hanging from the roof to minimise dust etc ) during the heat of the day ( well best that it gets around here during august perhaps 12 deg C- 2 deg c overnight ) , allowed me to keep the parts and paint more or less pretty warm well somewhat consistent at least . some colour applied , then back inside as the propellant vapours dissipate ...to cure in the fire place warmed living room .
looking promising with a few layers of clear coat too come
also working on the dash pad thingy ,
after suffering a failure to bond, aluminium solder bond stuff to weather protective box of sorts under the dash pad with some 1.2mm sheet , I figured that the sheet was probably finished with some form of anodising ...wtf ? , anyhow remade similar with some 2mm raw sheet , which worked well , and now with a bit more experience in the process , came out looking ok , for what I want to do .
now finishing off the remainder of the metal works before fitting indicating leds to the panel , im about to play with some liquid silicone to seal them off on the facia ...could turn out ok I guess (in a raw type finish that im looking for ).
