1 blinker malfunction Wed Nov 25, 2015 9:37 am
gmaizey
Hi All
The 1991 K100RS is slowly progressing from when it first arrived on the trailer from up north...
https://servimg.com/view/19367170/10
then I did the rear splines....
https://servimg.com/view/19367170/11
https://servimg.com/view/19367170/12
https://servimg.com/view/19367170/13
...but the real issue for this topic is related to in here
https://servimg.com/view/19367170/14
...when I turn on the ignition key the blue relay in the picture (maybe a load shed relay?) is clicking
...when I press the right blinker button both right hand blinker work fine but the blinker cancel button doesn't work
...when I press the left blinker button, the right blinkers work fine but the left blinker also come on and stay on, and the blinker cancel button still doesn't work
I have carefully taken apart the left handlebar switch, high/low beam, horn and left blinker button but there was no change....I will do the same with the right handlebar switch tomorrow
I guess my real question is about the blue relay and if the clicking there is normal or indicates it is Kaput..
