1Back to top Go down   Chassis number Empty Chassis number Wed Sep 02, 2015 8:34 pm
emmanuelfiadjoe
emmanuelfiadjoe
Please help me find the bike with chassis number wb10415a412e17128.
Model: K 100 RS 83 (0502,0503,0513)
Series: K589 (k100, RS, RT, LT)
Production Month/Year: 07/1984
Region: Europe
VIN: 0018945
2Back to top Go down   Chassis number Empty Re: Chassis number Wed Sep 02, 2015 9:21 pm
That number does not show as a genuine VIN are you sure it is correct
3Back to top Go down   Chassis number Empty Re: Chassis number Thu Sep 03, 2015 4:02 am
emmanuelfiadjoe
emmanuelfiadjoe
I think I got it right, nevertheless I'll check again
Region: Europe
VIN: 0018945
4Back to top Go down   Chassis number Empty Re: Chassis number Thu Sep 03, 2015 10:54 am
It doesn't work in BMWNA's Great Computer either. Check the digits around the last seven...something's amiss there.
5Back to top Go down   Chassis number Empty Re: Chassis number Thu Sep 03, 2015 4:20 pm
emmanuelfiadjoe
emmanuelfiadjoe
Its what I saw, exactly. I saw the bike in a workshop. I'm beginning to think the chassis number has been changed: a portion of the frame where I saw this number has been filed, and it looks as if an embossment has been taken off. Some bikes imported to this place are stolen from Europe or America. I think those who do this sometimes change the chassis number.
But the bike looks exactly like a BMW R1150R.
Chassis number ZChassis number ZChassis number ZChassis number 2Q==
Region: Europe
VIN: 0018945
6Back to top Go down   Chassis number Empty Re: Chassis number Thu Sep 03, 2015 4:41 pm
There should also be an aluminium plate fixed to the frame with 2 rivets.
7Back to top Go down   Chassis number Empty Re: Chassis number Thu Sep 03, 2015 5:53 pm
emmanuelfiadjoe
emmanuelfiadjoe
that was what I said has been removed.
You see the rivet holes and nothing else. that area looks as though it has been filed or ground. I think it was stolen and then imported.
Region: Europe
VIN: 0018945
8Back to top Go down   Chassis number Empty Re: Chassis number Thu Sep 03, 2015 6:51 pm
The last digits are normally a seven digit number and I ma just wondering if there should be one or two zeros? EU bureaucrats have everything set out a certain way to incorporate model codes etc in the VIN and its usually the last seven digits. The numbers are normally marked into the frame as well and if they are all present and clear then it should show up on a database somewhere.
But, as already pointed out, it doesn't seem to be a genuine number. I can do a web search on my car VIN and it will tell me manufacturer, model etc.
9Back to top Go down   Chassis number Empty Re: Chassis number Thu Sep 03, 2015 6:55 pm
An R1150R series VIN would be (starting with the tenth digit) ZF followed by five numbers. So, if we type in ZF17128 we see an 01/2001 R1150R non-US model. Perhaps this is what you're seeing but possibly misinterpreting.
10Back to top Go down   Chassis number Empty Re: Chassis number Thu Sep 03, 2015 7:20 pm
Two Wheels Better wrote:An R1150R series VIN would be (starting with the tenth digit) ZF followed by five numbers. So, if we type in ZF17128 we see an 01/2001 R1150R non-US model. Perhaps this is what you're seeing but possibly misinterpreting.
or that whoever has altered it has done it so it could be seen as a badly done stamping.
if you are considering buying it, I would not touch it even with a rubber finger.
11Back to top Go down   Chassis number Empty Re: Chassis number Fri Sep 04, 2015 4:50 am
emmanuelfiadjoe
emmanuelfiadjoe
I wouldn't buy it at all.
It sure is an R1150R, that I'm sure of. So I think its been altered.
Thank you all.
Region: Europe
VIN: 0018945
