1 Number 2 cylinder firing Sat May 09, 2015 4:01 pm
Walla Walla Willie
I have an 85 K100RT. Sat for six years before I bought it so I cleaned everything the fuel system interacted with including professional injector cleaning. Seems like #2 cylinder does not fire all the time. At idle, I can pull the injector connector off and no noticable drop in RPM. Pull any other injector connector and RPMs drop. Swapped injectors (2 and 3) with same result. Checked, cleaned, and swapped plugs. Same result. If I go out on hard ride, the #2 pipe at the head is as hot as the others. Go on an easy ride and it seems like #2 pipe is cooler than the other three pipes at the head. I test this b wetting a paper towel and pressing it against all four pipes. I do get a bit of backfiring occasionally particularly on downshift. Seems a bit rougher between 2500 - 3000 rpm. Above 4000 rpm, I roll on the throttle and it runs quick. I have run three tanks of gas through including seeking out non-ethanol gas. LOTS of new fuel parts given it sat. Fuel pump, filter, lines, etc. Fuel rail is clean and clear. About the only fuel part I did not replace is the pressure regulator but, if that is the problem, it seems like it would effect all cylinders and not just #2.
Any ideas? A bit stumped.
