1Back to top Go down   K75 Oil/Water pump rebuild Empty K75 Oil/Water pump rebuild Mon Apr 27, 2015 12:37 pm
bkhK75
bkhK75
I am rebuilding the oil/water pump on my 1992 K75 and have a part that I have not been able to identify.  It is a spacer/washer or something that was located between the slip-ring seal and the spacer bushing.  it is approximately 1/8" thick and has a rubber type material in the center where the shaft goes through like a seal of some sort.  It has a diameter slightly larger than the spacer bushing.  I had removed the rotor (stamped type) and the spacer bushing and was in the process of removing the shaft when it fell out of the housing so it was stuck to the seal I guess.  I would like to order a new one if I knew what it was.  Can anybody help me?  Thanks.
2Back to top Go down   K75 Oil/Water pump rebuild Empty Re: K75 Oil/Water pump rebuild Mon Apr 27, 2015 5:21 pm
I think we need a pic to identify this ...but sounds like a seal ?
if installed correctly the water seal does not need any spacing to the pre made spacer and the impeller
sounds like some one has installed it as a spacer ?
3Back to top Go down   K75 Oil/Water pump rebuild Empty Re: K75 Oil/Water pump rebuild Mon Apr 27, 2015 5:59 pm
As Charlie said, there is no spacer.
Would it be part of the mechanical seal?
Quite often they disintegrate and come out in pieces.
K75 Oil/Water pump rebuild Frog15K75 Oil/Water pump rebuild Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
4Back to top Go down   K75 Oil/Water pump rebuild Empty Re: K75 Oil/Water pump rebuild Mon Apr 27, 2015 6:07 pm
jandalboy
jandalboy
I'll second what crazy frog says.Thought the same thing when I rebuilt mine.And I only got it right on my second attempt.Good luck.
1990 k100rs low seat.
5Back to top Go down   K75 Oil/Water pump rebuild Empty Re: K75 Oil/Water pump rebuild Mon Apr 27, 2015 7:07 pm
Only one piece of advice: when assembling the new seal, do EXACTLY what is says in the documentation because if you don't, you WILL break it. No ifs, buts or maybes - it will break.
6Back to top Go down   K75 Oil/Water pump rebuild Empty K75 Oil/Water pump rebuild Tue Apr 28, 2015 1:23 pm
bkhK75
bkhK75
The old water seal did disintegrate when I removed it.  I couldn't figure out how to post a picture with my question.  Any idea where I can find a photo of an intact old seal to compare?
You guys on this forum are a wealth of knowledge and I really appreciate the help.
7Back to top Go down   K75 Oil/Water pump rebuild Empty Re: K75 Oil/Water pump rebuild Thu May 07, 2015 1:41 pm
gabriel
Hi everyone
The part you described is from the original water seal.
Previous topics in this forum have included a photo.
Ing will have a photo.
The design of this seal has since changed.
8Back to top Go down   K75 Oil/Water pump rebuild Empty Re: K75 Oil/Water pump rebuild Thu May 07, 2015 1:49 pm
gabriel
I managed to locate the previous thread.
It is titled "Gabriel original water seal" and is located on page 3 in the Your own renovation section of this forum.
Includes a photo courtesy of Inge.
thanks
