1 hazard lamp and BMU Mon May 25, 2015 5:12 am
Noeloakes
Hello All,
I recently decided to add a second tail/ stop lamp to the K1100LT, mounted to rear luggage rack. Just spliced the wires from existing set up. Noticed that hazard lamp is now pretty much constantly lit ( goes out after first deploy front and back brakes as normal but then comes on again) will now only go off if brakes are engaged.
Is it just the Brake Monitoring unit getting confused since I spliced to second tail light or something more critical? if the first and no harm likely I will leave it as is ..... any advice greatly appreciated,
Ride Safe, Go the Aussies.....
