1 Fuse blows Mon May 25, 2015 7:49 pm
Donmystic1
I recently picked up a naked 1985 K100 with only 13,000 miles.
When I flip the rocker switch for the heated hand grips the battery light comes on and I lose the idiot lights on the gauge panel.
I found that the 7.5 fuse is blown. Replaced it and tried again same result.
Upon replacing the fuse everything runs fine until i play with the heated grips rocker switch.
I am probably going to just take the heated grips off line.
Has anyone had a similar problem / fix ?
Don
Don
