1 Electrical components Location and Connectors Tue Jul 26 2022, 00:32
jjefferies
Just wondering if there's a single repository of information where various electrical functions reside and where their connectors are located. Yeah, I know that's wanting things made too simple but... My emergency flasher unit on Red isn't working. No big deal, it's optional and not needed until you're in trouble. But the Haynes manual shows it as the Hazard Flash Switch and has three wires, one a ground (I suspect all brown wires are grounds) and the other two connected to the flasher unit. As the turn signals work I would suspect it's a connector. I'm assuming the flasher relay is in the electrical box under the back of the gas tank and front of the saddle which has the fuses mounted on its side. So I'm trying to work out where the connector for the Hazard Flash Switch is located and I would prefer not to tear the whole bike apart trying to follow it. Any suggestions as to where a master list of devices and connectors might be located or where this particular connector might be found? I would Suspect alongside the main frame tube on the side but that's an hour or so to tear into it just to find out if I'm wrong.
best regards
JJefferies
best regards
JJefferies
