1Back to top Go down   adding a fuel guage. Empty adding a fuel guage. Sun Apr 04, 2010 11:54 am
croman
croman
this is my first post, so obviously i have a problem and any assistance would be nice.
i am attempting to fit a fuel guage to my 1987 LT and have a fuel guage( from motorworks-good lads).
it has an orange 4 pin connector and looking at the bmw wiring diagram there is a male connector that it fits into.
my query is where might this relevant connector be located on the bike.
i had the old girl to bits changing all the hoses yesterday and nothing shouted plug me in here!
of course the other issue is where to mount it as the factory fit speakers are where i have seen fuel guages in the past.
all ideas gratefully received.
2Back to top Go down   adding a fuel guage. Empty Re: adding a fuel guage. Sun Apr 04, 2010 10:40 pm
Hello Croman and welcome to the forum.
I am not familiar with the newest models of K100 as the early K100 has only 2 warning lights. In order to install a fuel gauge, you may have to replace the sender in the tank.
I will try to find the BMW reference for it.
Bert
adding a fuel guage. Frog15adding a fuel guage. Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   adding a fuel guage. Empty Re: adding a fuel guage. Mon Apr 05, 2010 7:09 am
Hi Croman,
Welcome to the forum. If you cannot mount it to the inserts above the knee boards, I have seen them installed into the knee boards themselves. There is a Y harness which connects to the take off point under the fuel tank and connects the gauge to the fuel sender. I think you should find the part on the Real OEM site or one of the BMW parts sites after you feed in the details of your bike to get the appropriate details up the part number of the Y may be 61-12-1-459-488 but check to be sure. Note the fuel gauge is specific to K bikes as it works back to front to most other gauges so if you fit one of the others it will read full when it is empty and vice versa. Check the download section on the site for the under tank connectors.
4Back to top Go down   adding a fuel guage. Empty Re: adding a fuel guage. Mon Apr 05, 2010 10:01 am
ReneZ
ReneZ
If your bike was not originally fitted with one, does the tank have a float or a thermal sensor (as per Bert's)? You have the right gauge but indeed need the bit of loom (which also has a green connector for the coolingwater temp meter) and a tank with a float sensor.
Rene
BMW K100 - 1985 (0030029) Scotland adding a fuel guage. Rain
5Back to top Go down   adding a fuel guage. Empty Re: adding a fuel guage. Tue Apr 06, 2010 5:03 pm
croman
croman
hello men,
thanks for the advice and have asked the boys at motorworks for the appropriate bit of loom. hopefully all will be well and i will go with the knee pad location.
regards
croman
6Back to top Go down   adding a fuel guage. Empty Re: adding a fuel guage. Fri Apr 09, 2010 1:36 pm
reg_K100RS
HI
I have an 87 K100RS and after adding an RT Fairing and bars I got some gauges from Ebay
which I find very useful and accuirate
The fuel gauge was the easiest ( least work) to fit
The 4 way connector was already in the rats nest under the tank
tucked down under the looms on the RH side half way up the spine
Hopefully you'll find yours there
IIRC the connector had
a live supply at igntion on
earth (brown)
fuel level sender (yellow?)
and lights
I'm a bit hazy on the colours as its been a while but I usually take pics and notes
when I;m tinkeng which I may be abke to dig out if youre struggling
I cut off the BMW roundish/flattish connector and made my own from parts I had to hand
but the shop bought loom may be easier for you
I taoped this connector for supply and lights to the temp gauge as well
As to where to fit it, well I know you can get pods for the gauges so thats one option
7Back to top Go down   adding a fuel guage. Empty Re: adding a fuel guage. Fri Apr 09, 2010 7:09 pm
ReneZ
ReneZ
Early bikes have a 3-way connector.
Rene
