Number of posts : 12058
You will need the OEM sender which will go on the pump. I believe you can get a VDO sender that will fit but it wont work with the OEM gauge so a VDO gauge will also be needed.
Personally I would go with a VDO set up as the OEM gauges are prooving difficult to get especially good ones with a clear lens.
