MikeisonTV
MikeisonTV
Having some trouble adding the fuel and water temp gauges back to the LT factory wiring harness.
The water temp gauge is working correctly. One down.
I get power to the red/white wire, the gauges I both illuminate green, but fuel gauge stays on E. I'm assuming there's away to test the float in the tank is functional?
Adding the Fuel level gauge and water temp gauge back... 82AAAF5A-7050-446D-8BD1-70DCEEDE3BB0
Curious what these unused wires go to as well.
I know one set is a lighter. Is there a diagram or...
1st set) red/white stripe & brown=_______
2nd set) grey/white strip & brown=_______
3rd set) green/black stripe & brown=______
MikeisonTV wrote: I'm assuming there's away to test the float in the tank is functional?
When the float arm in the tank being moved up and down, you should read
variable resistance to ground at the yellow wire.
1st set) red/white stripe & brown=_______power socket.
2nd set) grey/white strip & brown=_______map reading light.
3rd set) green/black stripe & brown=______cigarette lighter.
MikeisonTV
MikeisonTV
Inge, you are a legend. You always come through! thank you sir for always helping us
