1Back to top Go down   Temp gauge Empty Temp gauge Thu Apr 08, 2010 8:02 pm
badgerdid
badgerdid
I believe a temp sender can be fitted to the water drain plug on the k100, but can you then use normal gauges, theres a few on ebay and not too bad a price.
I believe they just need a 12v supply with the temp sender unit providing the earth via certain resistances, if this is the case then surely a sender and gauge from anything can be used?
what size sender unit (thread) do i need to screw into the drain hole?
Or am i thinking wrong?
2Back to top Go down   Temp gauge Empty Re: Temp gauge Fri Apr 09, 2010 12:45 am
reg_K100RS
Yep you can get the sender from motobins/works
heres the link to the bins page
http://www.motobins.co.uk/bmw-parts.php?model=K%20Series
Part No.87042
When I put an RT fairing on my RS I bought SH gauges from Ebay and the sender from
bins and did the wiring mods myself
Not sure how accurate non bmw gauges will be but as most of these things work in similar ways
(ie as you say by the sender controlling the flow of current to earth dependng on temp
which in turn deflects the gauge needle)
its probably worth looking at and you can alays keep an eye out for sh ones on Ebay
if your not happy with the results
3Back to top Go down   Temp gauge Empty Re: Temp gauge Fri Apr 09, 2010 8:47 am
green cat
green cat
badgerdid wrote:I believe a temp sender can be fitted to the water drain plug on the k100, but can you then use normal gauges, theres a few on ebay and not too bad a price.
you're totally right. I did it on my K 100 RS
[img]Temp gauge 3cc2228804714fdc8e93fe1f84a93706[/img][img]Temp gauge K1100l10
