1Back to top Go down   91 K100sr temp gauge Empty 91 K100sr temp gauge Thu Mar 07, 2013 4:50 pm
2slow
2slow
Has any body hooked up an after market gauge like a VDO gauge do you also have to change the sender I'm just looking for a gauge that has numbers on it thanks
2Back to top Go down   91 K100sr temp gauge Empty Re: 91 K100sr temp gauge Thu Mar 07, 2013 6:33 pm
If you mean temp gauge then I most certainly would change the sender, the sender is on the pump and is seperate from any other devices so all you need do is change the sender without wiring changes except to connect the gauge itself.
3Back to top Go down   91 K100sr temp gauge Empty Re: 91 K100sr temp gauge Thu Mar 07, 2013 6:55 pm
2slow
2slow
Thanks that's what I thought also do you know is that a 10mm sender?
4Back to top Go down   91 K100sr temp gauge Empty Re: 91 K100sr temp gauge Thu Mar 07, 2013 7:00 pm
2slow wrote:Thanks that's what I thought also do you know is that a 10mm sender?
No I don't know there was a thread some time ago about this so a search might turn something up but I won't look as I can never find anything with a search. I think it sees me coming and hides everything.
