1 ABS 2 Again Sat Oct 06, 2012 12:27 pm
gmcq
Another gremlin. Started of with two flashing lights. Made a LED test light that indicated front wheel sensor fault. On removal there was a split in the cable. So replacement sensor fitted. Now I have one flashing light! Memory reset, tested and no fault showing stored in the memory. Battery before starting is showing 12.4v and charging at 14.08v at 1500rpm. Tried the rolling start method but still one light flashing. When I use the reset button when moving the light stays on but stops flashing. I'm starting to get target fixation staring at this light! Any suggestions?
Gerard
Gerard
1996 K1100LTIC 0235790
