1Back to top Go down   For sale 3 spoke wheels K1100 Empty For sale 3 spoke wheels K1100 Tue May 05, 2015 5:29 pm
Whooo Hoooo...... finally got myself a set of 3 spokers . I hope no one else was eyeing these off.
Saw them last night on flea with the option of buy or bid .
 I figured the bids would probably go higher than the buy price so I procrastinated as long as I could and hit the button .
For sale 3 spoke wheels K1100 _5710
Now to get them home, hopefully I'll grab them when visiting the Sydeney guys for coffee. is there anyone in the area of Chipping Norton or Hilltop who could hold on to them till I get there? Thanks , Ed.
Now For Sale , due to incorrect description on Ebay . Scroll through for further info.
For sale 3 spoke wheels K1100 10_x_110
2Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Tue May 05, 2015 7:50 pm
JR_K100RS
JR_K100RS
G'day GroverK , just looking at that front wheel , do you have all of the other bits to go with it ( discs , forks etc ) is it the later 17incher ?
John R
3Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Wed May 06, 2015 6:57 am
Thanks for checking JR, I'm not sure how these codes are deciphered , but hoping that they will accommodate my existing fittings.
Rear wheel
For sale 3 spoke wheels K1100 _57_110
front wheel
For sale 3 spoke wheels K1100 _57_510
4Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Wed May 06, 2015 7:50 am
The rear wheel is a 3.00 x 17 Type A so is a K1100 LT wheel which will sit 14 mm to the left. I am currently investigating the machining of those to see if they can be fitted to a monolever and sit centre.
The front is a K1100 wheel and will need to be fitted with the K1100 305mm discs and the 41.7mm forks and 4 pot calipers etc etc. To be quite honest Ed they probably aren't worth it and as they were advertised for a K75/K100 then you have good reason to get the money back as they never came on either.
The K75s had 3 spoke wheels but were not the same as those and are the right ones to get. The front will take the 285mm discs and the rear will have type B stamped on it.
The 3 spoke wheels that TWB and Charlie have are the K100RS 16v but only the rear so as to fit a radial and they still sit 14 mm to the left.
5Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Wed May 06, 2015 8:50 am
Rick, I'm certain that this is the chap who was selling off a lot of 100RS stuff a few months back. i'm hoping that these rims suit.
6Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Wed May 06, 2015 9:46 am
I saw the add Ed and he said he bought them for a project and has since changed the ideas so doesn't need them and he may not even know that they don't fit a K100 with a monolever rear end.
Those wheels are from a K1100LT.  The K1100LT is the only model that had those size wheels.
If you want 3 spoke wheels the K75s wheels are the way to go IF you can find any. Even then you will need deep pockets.
If you fit the right front end and the paralever drive you may as well get the RS wheels and the wider radial tyres which make it a different bike.
7Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Wed May 06, 2015 11:27 am
RicK G wrote:The rear wheel is a 3.00 x 17 Type A so is a K1100 LT wheel which will sit 14 mm to the left. I am currently investigating the machining of those to see if they can be fitted to a monolever and sit centre.
To further it, the front 3 spoke wheel I have on my OZ RS is an 18" from a K75S which, as many agree, will bolt right on brakes and all with no dramas as it uses the four bolt pattern and not the 'floating' points of the later 305mm discs. Mind, I've added larger brake discs (292mm) from a Suzuki with an aluminium spacer behind, but the OEM 285mm discs fit straight on.
8Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Wed May 06, 2015 5:03 pm
thanks guys , I've sent the seller a message suggesting a refund if these wheels are not K100 as stated.
Rosskko is there much difference between Smurfette and your Basic? what numbers are on yours?
9Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Wed May 06, 2015 8:02 pm
groverK wrote:thanks guys , I've sent the seller a message suggesting a refund if these wheels are not K100 as stated.
Not sure Ed. Will have a look at the numbers this arvo.
I have two 3 spoke rears. One is the 4.5 and one is the 3. I don't have a front, but looking at my RS there is no way th front would fit the basic
10Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Thu May 07, 2015 2:39 pm
JR_K100RS
JR_K100RS
Yup agree with Rosskko , the front wheel should be one that uses 4 bolts to retain the discs I think
John R
11Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Fri May 08, 2015 7:21 am
The seller has offered the following info, sounds like all info kindly supplied by the forum is correct, much appreciated as well.
 As you can see , he has been kind enough to provide a refund should I cancel this sale,  but before I do , and these wheels are relisted , does anyone else have an interest in them? I am happy to take delivery and hold them if need be.
Hi There,
Unfortunatelly friday is no good i'm having a day off from work, back on monday arvo. As far as i know the 1100 has much wider rim, i had one of those rims fitted in my k100, took the advise that there is a little offset . Well it is about 25mm These rims are about the same with as the the ones i had in originally(honeycomb type) If you wish to cancel the transaction, no problem, let me know.
Steve
Hi There,
I just checked up on part numbers in my archive and they are K1100 wheels. They have the same characteristics as the K100. My mistake, i always thought they are K75 wheels.I had a K1200 in my K100 which is 5.5 inch wide instead the 3inch. I'm happy to go with the refund if you wish, pls let me know.
Steve
I'll confirm with Steve my intentions via email on Sunday night. Allowing time for anyone to grab these if they wish.
For anyone interested , I paid $227.00 AUD  , at buy it now price . This will be the same price if someone on the forum takes them. I can hold ( store them ) them if needed. Freight would be negotiable. Cheers Ed.
12Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Fri May 08, 2015 8:42 am
He's full of it Ed the K1200 5.5 rim wont even go close to fitting into a K100 even without a tyre just tell him to refund you.
13Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Fri May 08, 2015 10:56 pm
RicK G wrote:He's full of it Ed the K1200 5.5 rim wont even go close to fitting into a K100 even without a tyre just tell him to refund you.
I concur, a 5.5" from a K1200GT (not a 5" from a K1200RS or LT) will not fit on a Monolever K100 when even a 4.5" 3 spoke K1100RS wheel has an extremely tight fit. A K1200RS/LT 5" wheel will fit a Paralever with a 2mm spacer but with an offset from centre - but only with a 170/60 tyre. The 180/55ZR17 doesn't with enough room.
14Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Sun May 10, 2015 1:34 am
JR_K100RS
JR_K100RS
G'day GroverK ,
                       have a look through TWB's thread :
https://www.k100-forum.com/t2713-wider-wheels-radial-tyres-on-a-k100
basically , 2.5x18 front off a K75S with a 4.5x18 rear off a K100 16v or a K1100 , this combo will let you fit up a 110/80/18 front with a 160/60/18 rear , I'm running Michelin PR3's at the moment , I've found that the offset to the left on the rear has not affected the handling in any way that I can detect
John R
15Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Sun May 10, 2015 3:02 am
yeah best to just get the refund ed .
the 3 inch rear would be useable but is a big price for just 1 rim ( and not much bigger in width )
the 90-93 s version of the k75 3 spoke is going to be hard to find out here ...but not impossible    don't give up mate
motor works list such a devil   WHK10734 (also the wrong picture )  in their used parts ...at 170 pounds  that's 300 and something aussie dollars + plus shipping  and that isnt cheap nowadays
best to troll and save a search in ebay maybe ?
id be quessing that usa might have a fair chance of a hit sooner than most others,  although there are some interesting surprises in Europe time to time
16Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Sun May 10, 2015 4:50 am
Tis almost time to cancel my purchase , I had a query today from an in law , will the rear K1100 3 spoke wheel from this set fit the rear of an R1100RS?
17Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Sun May 10, 2015 8:30 am
The R1100RS has the 18 x 4.5 which is the same as the K1100RS
18Back to top Go down   For sale 3 spoke wheels K1100 Empty Re: For sale 3 spoke wheels K1100 Sun May 10, 2015 9:44 am
thanks to everyone , I've posted a message back to Steve requesting a refund . I hope he has a more positive response next time they are listed.
As for myself it has been a lesson learnt . It is very much appreciated the info provided here on the forum, a shame to miss out, not to worry, I'll continue to keep an eye peeled.
