1 Five spoke K12 wheels on a K11/K100/K75 Wed Jan 14, 2015 2:20 am
At last, I've found it! This works for all K1200RS, K1200GT-Brick or K1200LT front wheels.
If a K1200 series, five spoke, 3.5x17" wheel is what you'd like to swap onto your K bike's three-spoke or Y-spoke front end so you can use a 120/70ZR17 tyre and four-piston Brembo brakes, the bearings you'll need are 25x47x14 RH side, and 25x47x20.6 LH side, due to axle diametre and length. You can't get these from a BMW dealership. You use your original 25mm diametre axle.
The industry number for a 25x47x14 sealed ball bearing is 62005-RS
The industry number for a 25x47x20.6 can be made by combining two sealed bearings in the single bearing's bore. They are 25x47x8 sealed bearing which is a 16005-2RS, and a 25x47x12 sealed bearing which is a 6005-2RS.
There is no 25x47x20.6 bearing that I can locate from any manufacturer, even from those Chinese bearing companies on eBay, etc., that claim to have everything.
The .6mm difference is nearly made up by the two bearings being placed side by side in the wheel (spreads the load nicely), and/or one can have their favourite machinist fab a slightly wider (.5mm+/-) replica of the collar to accommodate this miniscule difference. I have seen it work and it is easily done. A mate has just completed this on his R80 using '95 K1100LT forks, axle and both collars over a K12 front wheel. The preload is correct and the wheel spins freely with no discernible or excess free play. The wheel/brakes are centred in the forks.
A 25mm between-the-bearings centre spacer is required, part number
36 31 1 458 419, from BMW for about $12.00. You can use your original axle collars on the later wheel, and they get modded slightly.
No stainless steel axle fabrication is required.
The R1150R/RS/RT series front wheels require different dimension bearings. Further research is required for those wheels.
I am using an earlier 5x17" rear K1200RS wheel on a Paralever final drive and there is no real clearance or offset issue to speak of with a 170/60ZR17 tyre. The 5.5x17" may cause clearance minor issues with a 180/55ZR17 or larger tyre. Add or remove the 2mm shims to your liking.
1977 R75/7-100, '93 K11/K12 Big Block, '93 K1100RS, '95 R100 Mystic, '96 K1100RS, 2 x '98 K1200RS, '06 K1200R & '09 K1300GT
