K1100 no power at starter Tue Mar 17, 2015 3:33 am
Packo
![Packo](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
![Silver member Silver member](https://i.servimg.com/u/f80/11/71/56/74/bmw-2s10.gif)
I am in the process of installing a K1100 upgrade.
I have put the 1100 in the 100 frame together with the loom, relay box and all engine componentry.
I have gone as far as just the engine, gearbox and loom in and thought I would see if I had it all together correctly.
Lights and chassis functions seem to operate as they should ie idiot lights in cluster, hi/low beam, parking light and flashers
When I press the starter I get nothing. Tried to follow Berts trouble shooting guide but not sure how to test the starter relay.
I have power at the start button when I pull in the clutch.
I have neutral light and 0 on the GPI
I have power at the starter relay on pin30 but none of the other pins have power at any time with or without pressing the start button
I am not sure how to proceed with testing from here, because of this I swapped the relay over for the one which came out of the bike when it was a K100 ( I assume it is still good, it was last week before I stripped the bike) but no change.
I do not have power at the starter when I push the start button.
Please advise on how to test from here, any advice will need to be in real laymans terms as I really struggle with electrics, Berts trouble shooting guide even baffles me.
PS : forget to mention, I have not put on a stand so I joined the wires from the sidestand switch together.
______________
83 K100 HRD Outfit
1992 K1100 Outfit
2003 R1150 GSA Outfit
1983 K100 Basic
