1Back to top Go down   Alternator Brushes Empty Alternator Brushes Fri Jan 30, 2015 11:32 am
cliverocky
cliverocky
Has anyone done their own alternator brushes?
Cannot find any information on how to do on web
But i assume it is unsolder then clean up then re-solder allowing a max of 10mm to stick out
Clive
2Back to top Go down   Alternator Brushes Empty Re: Alternator Brushes Fri Jan 30, 2015 1:55 pm
That's about it Clive. After you pull the old brushes out run a 1/16 drill through to make the hole big enough and most auto electricians will have the brushes for about $5
3Back to top Go down   Alternator Brushes Empty Re: Alternator Brushes Fri Jan 30, 2015 5:29 pm
important thing to add clive ,,,don't tell them its for a motor bike ....but for a vw ....then all will be available and well known by the auto electrician
just a heads up
good luck !
