1Back to top Go down   starter question Empty starter question Thu Dec 13, 2012 11:35 pm
thegreatford
thegreatford
I got a non-running 91 k100 found a bad fuel pump. The engine turns over several spins then slows down like dead battery, new battery and same thing. Plugs out and spins great. Does this sound like a bad starter? Is this common? I have fire and new fuel pump ready to install.
2Back to top Go down   starter question Empty Re: starter question Thu Dec 13, 2012 11:58 pm
Greetings and welcome to the forum. When you get a mo' pop on over to the new member's intro page and tell us about yourself and your new bike. We love pictures too. Once you've done that the Admin dude, Crazy Frog, will give you the password to access the download page and a whole heapin' helpin' of K bike info will appear for you to peruse at your leisure.
It's common for the starter motor to 'dust up' due to the brushes spreading carbon around the joint over time. It ought to be a maintenance item it's so common. It causes all manner of strange issues. If you're handy with a spanner and inclined to go have a look it might be worth yanking the starter out and disassembling it with an eye to cleaning it out with contact cleaner and/or replacing the starter brush pack.
The Google search engine in the forums two main pages will turn up heaps of info on how to extract the starter.
Cheers.
3Back to top Go down   starter question Empty Re: starter question Fri Dec 14, 2012 12:00 am
Sounds to me like the brushes are on their last legs. You can buy just a brush kit that has the plate included but before that check the earth connections at the gearbox just above the coils and the frame connection which is the engine mount bolt on the right just above and back from the alternator cover. Also the two bolts that hold the starter if there is corosion there its bad news.
Make sure you clean the fuel tank as we see many problems here because a new pump was installed and the tank not cleaned of the remainders of the dead vibration damper.
4Back to top Go down   starter question Empty Found bad brushes Fri Dec 14, 2012 10:54 pm
thegreatford
thegreatford
Pulled the starter today and opened it, found the bad brushes as was suggested. Thanks for the good advice.
Will try and find brushes on Monday.
