51 Re: Starting issue.... Tue Feb 03, 2015 8:28 am
kioolt
The results of step one and two indicates wiring going to switchgear or switchgear problem.BooG wrote:1) r/h switchgear disconnected under tank. Key turned to "on": load shed clicks, nothing else works. No click from starter relay.
2) Switchgear reconnected. Load shed relay removed: Key turned to "on". original problem again; turnover from key "on" position.
3) Load shed removed. Wires disconnected from starter relay. No voltage from terminal 86 on relay with key at "on" or "off".
12v at the connector wire (black/yellow) when disconnected from relay.
4) Load shed relay removed. Wires out at starter relay. ICU/ECU disconnected. Ground run from terminal 85 on starter relay. No click from relay.
5) Load shed in place. r/h switchgear disconnected under tank. wires off starter. 12v at connector wire (yellow/black for terminal 86 on starter relay).
Seems like the power is finding its way to the starter relay from the black and yellow wire. Also, there does appear to be "suspicions" concerning the starter relay.
I think the switchgear is OK. Cup of tea and on again. My fingers are killing me....London v.cold today!!
In step three and four I believe you misunderstood what I wanted you to disconnect. Disconnect the big wire on the STARTER at the starter not the starter relay. Regardless of you removing the wire at the wrong place, the problem appears to be in the switchgear wiring or switchgear. I will look at the diagram again to see if I can get a clue as to where it might be in that section of wires.
I see no suspicions concerning the starter relay at all from your description above. No voltage on terminal 86 at starter relay no WORKEE just as it should not work.
