1Back to top Go down   Starting issue Empty Starting issue Wed Sep 29, 2010 11:53 am
Kallack
Hopped on the bike yesterday while running arrands on my second stop of the day and pushed the start button no starter. The lights where all on as normal and the fuel pump started running but the starter did not turn. Bumped the bike back and forth in gear a couple of times and whoa it started but I didnt have any turn signals, pushed the turn signal on and both blinked once then nothing. So I'm guessing after looking around at other posts that the starter brushes are probably the problem or at least a good starting point just wanted to see if you guru's agreed and or had more insight.
Thanks,
Dave
2Back to top Go down   Starting issue Empty Re: Starting issue Wed Sep 29, 2010 12:44 pm
We agree 100%. A good overall of the starter is the first thing to do.
Bert
Starting issue Frog15Starting issue Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   Starting issue Empty Re: Starting issue Thu Sep 30, 2010 1:54 am
Yep Kallack,
You nailed it the most likely cause is the starter brushes.
4Back to top Go down   Starting issue Empty Re: Starting issue Thu Sep 30, 2010 5:14 am
green cat
green cat
One more... starter brushes Twisted Evil
[img]Starting issue 3cc2228804714fdc8e93fe1f84a93706[/img][img]Starting issue K1100l10
5Back to top Go down   Starting issue Empty Re: Starting issue Sat Oct 02, 2010 3:27 pm
Adiwan Djohanli
Adiwan Djohanli
What happen to the turn signals then???
Like to know and learn more.
Thanks.
Adiwan Djohanli
Jakarta-Indonesia[i]
6Back to top Go down   Starting issue Empty Re: Starting issue Sat Oct 02, 2010 9:23 pm
Ned
Ned
Adiwan Djohanli wrote:What happen to the turn signals then???
Thanks.
In my case the signs of the starter problems become apparent when the lights and blinkers started to misbehave. The lights started to blink as a function of revs and the turn signals went on/off randomly.
Next, the bike stopped and refused to turn over until I bumped it as described by Dave.
The point I am making is that the starter problems cause all kinds of seemingly random problems with the electrics. I guess that if it is connected to the load relay, it will misbehave. Ignition and FI are on a separate circuit, so they work even if the starter circuit/load relay are playing up.
Ned
7Back to top Go down   Starting issue Empty Re: Starting issue Sun Oct 03, 2010 2:43 am
Adiwan Djohanli
Adiwan Djohanli
Hello Ned,
Your case confirms my situations with my bike. Turn signals and headlight are not working properly.
But the bike starts and runs well so far.
Cheers.
Adiwan Djohanli
8Back to top Go down   Starting issue Empty Re: Starting issue Sun Oct 03, 2010 5:36 am
ReneZ
ReneZ
Adiwan, have a look at Bert's schematics, then the function of the load-shed relays and the ground connection over it becomes clear. If not just ask.
Rene
BMW K100 - 1985 (0030029) Scotland Starting issue Rain
9Back to top Go down   Starting issue Empty Re: Starting issue Sun Oct 03, 2010 3:00 pm
Adiwan Djohanli
Adiwan Djohanli
Yes Rene,
I am studying the electrical schematics. I need to learn a lot and also trying to source the required parts locally. Smile
Thanks.
Adiwan Djohanli
10Back to top Go down   Starting issue Empty Re: Starting issue Mon Oct 04, 2010 11:59 am
green cat
green cat
The brushes cause a problem of ground connection and the effects are quite interresting. It could take place in the headlights, the turn signals, sometimes the horn ... or everywhere else on the electrical circuits of your bike... Evil or Very Mad
11Back to top Go down   Starting issue Empty Re: Starting issue Mon Oct 04, 2010 12:08 pm
Good point Green Cat. It affects everything fed by the load shed relay. The temperature switching unit can be affected too.
12Back to top Go down   Starting issue Empty Re: Starting issue Tue Oct 05, 2010 12:29 am
Probably one of the issues is the load shed relay starts to chatter in and out with the result I imagine the headlight would eventually look like demented Aldis light when it gets really bad.
