1Back to top Go down   Substitute fuel pump Empty Substitute fuel pump Tue Dec 16, 2014 6:41 pm
I've just bought a replacement fuel pump from these people:-
http://www.ebay.co.uk/itm/351180041171?_trksid=p2060778.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
It's an exact replacement, (correct diameter and electrical connections) for our Bosch pumps for less than £50.
And, from the pictures, it looks like the ones that certain well known suppliers are selling for £157!
2Back to top Go down   Substitute fuel pump Empty Fuel pumps Tue Dec 16, 2014 8:33 pm
gladstone sa old fart
Here is a list that I have for fuel pumps
HOLDEN Commodore VK EFI, VL turbo and non turbo, VN onwards V6 and V8 sedan wagon statesman
HOLDEN Camira JD JE Astra Calibra
FORD Falcon XE XF EFI sedan only
FERRARI 412i Coupe
NISSAN Skyline Pintara Pulsar Bluebird
ALFA ROMEO 33 Alfetta 75 90 GTV Spider
BMW M3 E30 M5 E28 318i 320i 323i 325e 325i 520i 525e 528i 535i 633Csi 635Csi 733i
CITROEN
FIAT Argenta Brava Regata Strada Ritmo X19
JAGUAR XJ6 XJs Sovereign
LANCIA Beta Delta Gamma Prisma Trevi Y10 Turbo
LOTUS Esprit Turbo
MASERATI Bi Turbo
MERCEDES-BENZ
MG Metro Turbo Maestro Montego
MITSUBISHI Colt Turbo Lancer
OPEL Ascona Corse Kadett Manta Monza Omega Rekord Vectra
PEUGEOT 205 309GTi 405 505
RENAULT R5 Turbo R11 Turbo R18 Turbo R19 R21 Turbo R25 Turbo Espace Quadra Fuego
ROVER SD1 Vitesse 3500 Vanden Plas RANGE ROVER LAND ROVER 3.5 & 3.9 EFI
SEAT Ibiza Malaga
VOLKSWAGEN Transporter Caravelle
Hope this is a help to others
PJ
http://pjingladstonesa.blogspot.com
3Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Tue Dec 16, 2014 8:54 pm
And they are just the ones that fit into the vibration damper. There are many others that will get you going if you're stuck by the roadside. I have used pumps that are smaller in diameter and put a large and strong cable (zip) tie around the damper and pulled it up to hold the pump. Any pump that will meet the pressure and volume requirements will run the FI.
4Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Tue Dec 16, 2014 11:23 pm
Ah, how at times we pine for the good old, gravity-fed days when all one did was reach down under the petrol tank and move the lever on both sides one soft click down to the auf position...and away until she stumbled and coughed well down the road, then it was another movement up past zu to res.
Substitute fuel pump Auf_zu10
No wizardy electrics, minimal fuss, a set of points, a condensor and two sparkies.....
Oh, yeah, but it was barely 60 horsepower, crap brakes (the original ABS - couldn't make 'em skid), hard, skinny tyres, oversprung and underdamped suspension, a willowy frame, constant pushrod seal leaks, often imbalanced carbies, and only 280 Watts of juice....the good old days.
Substitute fuel pump Airhea10
5Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Wed Dec 17, 2014 12:39 am
Do you mean when it goes cough cough and you reach down to put it on res and OH F*$# NO IT"S ALREADY THERE Substitute fuel pump 61740
6Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Wed Dec 17, 2014 1:17 am
Be made
Be made
gladstone sa old fart wrote:Here is a list that I have for fuel pumps
PJ
Thanks for this. Appreciated
7Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Wed Dec 17, 2014 1:20 am
Be made
Be made
Two Wheels Better wrote:....the good old days.
I still have a soft spot for those old 1000cc boxers.
They rock in my book. 115mph is plenty and 25mph to 115 in top and maintenence is a joy to do on them.
So simple and yet so practical
8Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Tue Jan 20, 2015 1:30 pm
moultonlava
moultonlava
Having just redone the inside of my tank after ethanol digested my  vibration damper, I can say this this is nice little pump.
https://www.amazon.com/gp/product/B000BZGGXO/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
...and when used in conjunction with this adapter fits perfectly.
http://www.euromotoelectrics.com/mobile/Product.aspx?ProductCode=FP-576FOAM
9Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Tue Jan 20, 2015 3:13 pm
Replacement pumps can also be found by these (part)numbers;
VW 4A0906087A
VW 441906087E
VW 441906091C
VW 441906091E
VW 441906091F
VW 8A0906091A
VW 8A0906091G
VW 895906091C
VW 895906091D
Bosch 0580314068
Bosch 0580453081
Bosch 0580453070
Bosch 0580453071
Bosch 0580453060
Bosch 0580453058
Bosch 0580453054
Bosch 0580453046
Bosch 0580453041
Bosch 0580310007
Bosch 0580310006
Substitute fuel pump Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
10Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Wed Jan 21, 2015 12:07 am
brickrider
brickrider
"still have a soft spot for those old 1000cc boxers.
So simple and yet so practical"
Exactly! That's why I'll ride my 1983 R100RS 'til the sun sets on my journey.  Very Happy
11Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Mon Jan 22, 2018 6:40 am
Beamer
Beamer
This supplier is not the cheapest on the block but it looks well informed about models and OEM part number and suggests the follow Bosch number:
Fuel Pump In tank 0580463999 Bosch
https://www.ebay.fr/itm/New-Genuine-BOSCH-Fuel-Pump-0580463999-Top-German-Quality/401456337665?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20170831090034%26meid%3Dac45a4573b9a4b8384f7bbfbdf6895e1%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D263419599311&_trksid=p2047675.c100005.m1851#shpCntId
There are cheaper options for that ref. , is this valid?
Does BMW generate a new part number for the same pump for every year of every model where it is used ??
12Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Mon Jan 22, 2018 7:26 am
RicK G wrote:Do you mean when it goes cough cough and you reach down to put it on res and OH F*$# NO IT"S ALREADY THERE Substitute fuel pump 61740
Been there done that
More than once  scratch
13Back to top Go down   Substitute fuel pump Empty Pump filter Mon Jan 22, 2018 7:47 am
Garyk100
Garyk100
Yep lots of aftermarket pumps around, anyone point me where I can get the plastic mesh filter that goes on the bottom of the pump, the original round ones are nearly the same price as the pumps
The early bird catches the worm, but the second mouse gets the cheese
1991 K100rs16v
14Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Mon Jan 22, 2018 8:21 am
Beamer
Beamer
Garyk100 wrote:... the original round ones are nearly the same price as the pumps
BMW want 500 euro-bucks for a pump here. How much is your filter?
15Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Mon Jan 22, 2018 8:49 am
Garyk100 wrote:Yep lots of aftermarket pumps around, anyone point me where I can get the plastic mesh filter that goes on the bottom of the pump, the original round ones are nearly the same price as the pumps
Get a pump for a VL Commodore and use the filter that fits on them. Done it a few times and works well.
16Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Mon Jan 22, 2018 8:57 am
Garyk100
Garyk100
$47 for the fuel pump strainer, Munich has 52mm pumps for $299, eBay under $100 but no strainer
1991 K100rs16v
17Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Mon Jan 22, 2018 9:01 am
Beamer
Beamer
Is that the colostomy bag type filter? I've seen a few pumps like that but not sure whether they would fit in the tank correctly.
18Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Mon Jan 22, 2018 9:22 am
Garyk100
Garyk100
Thanks RicK, I have that style in the 11, I have my original pump for the 16v k100 and the round basket style strainer is stuffed, was hoping to find a cheep strainer
1991 K100rs16v
19Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Mon Jan 22, 2018 9:55 am
Beamer
Beamer
Gary, I'm guessing that he gauze is damaged.
Instead of $50 for 2c bit of plastic, maybe you could keep the basket and attach another nylon  gauze from something like a chainsaw air filter or similar, using hard plastic cement or suitable adhesive.
It's really annoying the stupid money BMW want for these bits and pieces. The rubber virbation damper is 99 euros. I'm going to need to look at replacing that too. Sad
20Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Mon Jan 22, 2018 3:15 pm
A mate rebuilt his filter screen with what I believe is Termi Mesh. Substitute fuel pump 44271 And silver soldered it together. Substitute fuel pump 112350
21Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Mon Jan 22, 2018 8:09 pm
Packo
Packo
Garyk100 wrote:Thanks RicK, I have that style in the 11, I have my original pump for the 16v k100 and the round basket style strainer is stuffed, was hoping to find a cheep strainer
Maybe this will do the trick if a few members get together
https://www.aliexpress.com/item/Free-Shipping-Diameter-52mm-Strainer-Electric-Fuel-Pump-Filter-for-FIAT-LANCIA-1984-1996-OEM-0580464998/32829653338.html?spm=2114.10010108.1000014.8.5838aa84f2E2Dt&traffic_analysisId=recommend_3035_null_null_null&scm=1007.13338.80878.000000000000000&pvid=fe8e13de-113d-40b8-beef-6626810e1048&tpp=1
______________
83 K100 HRD Outfit
1992 K1100 Outfit
2003 R1150 GSA Outfit
1983 K100 Basic
22Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Mon Jan 22, 2018 8:10 pm
It sure does fit Beemer, I have found that folding the long mesh bag in half helps heaps getting it in
Terminesh would be about as useless as tits on a frog, the pumps will likely jam if particles over 6 microns get through and that mesh is about 25 microns if memory serves me correct.  Good for straining the peas or pasta but not fuel.
23Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Tue Jan 23, 2018 12:47 am
Beamer
Beamer
Thanks for the confirmation Rick. I opted for genuine Bosch pump this time. It cost me about 50% more than a noname. I need another at some stage for another bike, so now I have a larger choice.
Obviously if a substitute material is used for the filter it has be fine enough. Gluing a bit of fly-screen on would not help.
24Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Wed Jul 03, 2019 3:43 pm
John A
John A
Just ordered this lot of strainers. I will be installing one once they arrive, looks like late July. I'll let you know how it works out for me.
1985 BMW K100RT Vin: 0051738 (old style tank)
1982 Suzuki GS650GL
25Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Thu Jul 04, 2019 10:58 am
Beamer
Beamer
That's for bringing this back up. I think I'll buy the pump which shows up next to that filter.
https://www.aliexpress.com/item/32809858739.html?spm=a2g0o.detail.1000060.1.6fcd60d6Gmxh37&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.90158.0&scm_id=1007.13339.90158.0&scm-url=1007.13339.90158.0&pvid=c4cf863f-94dc-43b7-b0da-b56ad2126d9b
Last time I paid 100 Brexits from  a UK outlet. Half that price with a filter suits me a lot better.
If they managed to tell the diameter, it would be helpful...
26Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Thu Jul 04, 2019 12:29 pm
John A
John A
Beamer wrote:That's for bringing this back up. I think I'll buy the pump which shows up next to that filter.
If you haven't ordered already, this link has the pump with the filter. Specifies 52mm;
https://www.aliexpress.com/item/32839461036.html?spm=2114.search0104.3.22.3d735c26io6ms1&ws_ab_test=searchweb0_0%2Csearchweb201602_7_10065_10130_10068_10547_319_10546_317_10548_10545_10696_10084_453_454_10083_10618_10307_537_536_10059_10884_10887_321_322_10103%2Csearchweb201603_60%2CppcSwitch_0&algo_expid=20d2f224-ac59-4cb6-ab61-799dc1eb14f3-2&algo_pvid=20d2f224-ac59-4cb6-ab61-799dc1eb14f3
~$33 after shipping.
1982 Suzuki GS650GL
Chewbacker
Chewbacker
as above
28Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Tue Aug 06, 2019 8:10 am
nino
I have Pabokay pump from Aliexpress. Exactly the same as original. Six months in tank and runs very well. They advertised filter but never send it.
The pump is quieter than old original pump. I believe Bosch sold  whole production line to Pabokay.
Regards
29Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Tue Aug 06, 2019 12:29 pm
Beamer
Beamer
"I believe Bosch sold  whole production line to Pabokay."
What is the reason for that belief? Do you have some info or are you just guessing because it looks identical?
30Back to top Go down   Substitute fuel pump Empty Re: Substitute fuel pump Tue Aug 06, 2019 4:58 pm
nino
100 percent identical, plastic parts, metal parts. Its old production line from eighties. Pabokay probably signed obligation to send some quantities for Bosch network.
I dont have a proof but its obviously produced on same machine
