51 Re: 1 hole Vs 4 hole injectors Fri Apr 01, 2016 9:00 am
about 3 bar mate (vacuum hose disconnected ---which gave it about 2.5 - 2.7 bar with vacuum pulsing at idle ) ...the spray pattern on these injectors seams to benefit the slight extra pressure
note I retracted the afm springing back to 1 click down from standard ,( could have left it at 2 clicks down in spring tension but felt that economy would suffer greatly ) ...and relocated the wiper to achieve 1.16 volts on closed throttle instead of the 1.68 or something that I read as static settings before I started on this particular afm . thats from memory .
which kinda comes into line with the link I found for some measured standards ...that could have been from a much younger and unmolested afm - bike
