1Back to top Go down   Bulb monitor Empty Bulb monitor Thu Oct 16, 2014 6:41 pm
electric_monk
electric_monk
Over the last couple of weeks my bulb monitoring warning light has been flashing intermittently yet both the bulbs are working fine. When it flashes I just tap one or other of the brakes and the light goes off.
I suspect it could be the bulb monitoring unit itself but can't find any info on it in my clymer manual....where to hell is it? and what does it look like?
Am I even barking up the right tree?
2Back to top Go down   Bulb monitor Empty Re: Bulb monitor Thu Oct 16, 2014 7:02 pm
BMU you find in the middle of the LHS in the relay box.
Also check that the bulbs have good ground connection.
3Back to top Go down   Bulb monitor Empty Re: Bulb monitor Sat Oct 18, 2014 4:21 pm
had the same issue a couple of times
the tail light globe was just about on its last legs and a slight bit of corrosion in the bulb holder socket  as I hit a bump it would come on mysteriously .
changed the globe and cleaned up the corrosion and added some deoxit ....all good since
