C_Mick
C_Mick
I recently serviced the rear brake master cylinder of my K75S and today I reassembled the rear brake line and RHS foot rest plate. I had previously unscrewed the connector for the rear brake stop light but I had tucked the lead away, out of sight while working on the bike. Out of sight - out of mind; it's true! Now I can't remember how the wire for the brake light switch clips on to the frame of the bike, although I think I know where the connector screws into the brake pedal. I can't see any obvious clues so maybe I need to take the footplate and brake pedal off again. I should have made notes or taken photographs I know, but if anyone has a line drawing of how the rear brake light switch is installed, I'd be grateful to have sight of it.
Cheers, Chris
Two wheels good...Four wheels bad...
chris the cable tucks in behind the rear master cylinder resevoir and follows the top of the side foot plate with a couple of clips ...and drops almost vertically to the switch near the master cylinder itself .
sorry i didnt take pics of this part specifically when i did a refurb recently .
but hope this helps
Rear brake light switch - a senior moment Pics_040
C_Mick
C_Mick
Thanks Charlie, that should do the trick. I'm learning a lot about things I previously never gave a second thought. When screwing the switch into place on the brake pedal how do you avoid twisting the wiring? Is it necessary to trace back to its connector and pull that apart, or is there an easier way?
Regards, Chris
Chris, you can disconnect the other end, screw it on and re-connect.
Or, what I do (the lazy way...) is twist the cable a few times in the opposite direction and then screw the switch into place. The cable will un-twist and all should be good.
C_Mick
C_Mick
Thanks Blakey, I'll give the lazy ahem! I mean energy-saving method a go first.
RSMITH
RSMITH
sorry to butt in here....
i have a sticky rear brake light switch and have tried cleaning and lubricating it on the bike to no avail. I am going to have to remove the switch and try clean it by soaking it in a mild cleaing solution.
can you guys perhaps tell me where the plug connector for the switch is on the bike. I would imagine it is on the right side of the bike, but if I may where exactly is the plug located?
many thanks
walfish
walfish
RS - you will need to remove the right footpeg assembly, switch is tucked in there.
Rear brake light switch - a senior moment Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
RSMITH
RSMITH
found the switch but where does the plug for wire the switch plug in, is it under the tank or does it connect straight into the BMU?
Under the right side battery cover.
RSMITH
RSMITH
hmm...... its not there? maybe previuos owner moved it? thanks I was hoping it would be more simple.
None the less, i am off to bed will have a go tomorrow after work.
was thinking - How could we go about doing a fuel consumption thread were we could post our real life fuel consumptions so we can all get a realistic datum for this , something to include make/brand/ octane rating of fuel, number of litres and distance covered?
cheers for now
Should normally be a two pole connector, with two yellow wires at the switch end
and one green/black and one gray/green wire at the harness end.
walfish
walfish
sorry - i'm having a senior moment.
Inge - is correct
13Back to top Go down   Rear brake light switch - a senior moment Empty Fuel monitor Sun Jun 10, 2012 7:18 pm
ReneZ
ReneZ
Hi, re fuel monitor, there is a German site with info: spritmonitor.de
I have my info in my signature on some fora, but haven't been able to get it done here yet.
Here's an example what you can show:
Rear brake light switch - a senior moment 266393_5
Rene
BMW K100 - 1985 (0030029) Scotland Rear brake light switch - a senior moment Rain
RSMITH
RSMITH
morning all.
thanks for that - i had a look at the site- very good.
if i go according to that then my bike is running as per normal fuel consumption. I suppose it is a heavy bike and i am a big bloke too.
thanks again.
will go through the bike again and try to fix up the rear brake light.
1984 K100RT (Trans Karoo Express)
Set phasers to "fail"........................ If I were Britianna I would waive the rules.........
chasing echo's mostly.................
MartyB
MartyB
Hi Chris, You're not alone mate. I had the very same Senior Moment with my bike but hadn't got around to asking yet. I was wondering about disconnecting or pre twisting too so it went on the back burner while I did something else. I took a heap of pics before I pulled bits and pieces off but obviously not enough. I'll have to go look now.
Marty.
1985 K100RS (0085223) to naked
RSMITH
RSMITH
Inge K. wrote:Under the right side battery cover.
I found the connector thanks- it pushed all the back into the bike between the frame.
I took it out tried to clean it up as best as possibble but unfortuneatly can only get the switch to work if I pull the little plunger out right to the bottom. It is quiet stiff to pull it to the last section to the end and it almost gets stuck there- so I assume the switch needs to replaced.
I am trying to locate the BMW part number for the switch on Real OEM.com to no avail. Do any of you know what the part number is so I can get availability info from my local BMW Motorrhad dealer.
many thanks
RSMITH
RSMITH
Thank you.
is that the "piston" type switch for non ABS? The early type
Yes, that`s the switch which fits your model for rear brakes
(and a some other things.....front brake, choke , clutch).
RSMITH
RSMITH
Great - thank you very much again Inge.K
Cheers!
RSMITH
RSMITH
morning all.
update- got the switch working- no have a fully functioning BMU, all lights working including insrument cluster, park lights ect
thanks all
Hooray!
Don't ya just love it when it all works!
RSMITH
RSMITH
very much so.
to me that is what biking is all about- riding and repairing yourself.
although I would LOVE a brand new bike, I can't see my repairing Ethos being able to be carried through in its entirety
Really? A new bike?
What, ride it everywhere, park it and look at it? No need to touch it with a set of spanners?
How boring would that be! Wink
RSMITH
RSMITH
Exactly.........
some of my mates dont get it, they are always moaning about always being in debt with the money borrowed to buy the bikes- fortuneatly I dont have that and I might use a bit more petrol than they do when on runs , but yes I try to ensure that my bike is always "ready to ride", and so far have only ever been left behind on the road with an old bike. ( that was because of a fuse box on my suzuki that melted as a result of the regulator packing up- there was nothing I could have done about that- but I still got home!)
I like working on tmy bikes.
26Back to top Go down   Rear brake light switch - a senior moment Empty Rear brake pedal wiring Tue Feb 12, 2013 2:59 pm
paul.dickson_VA
paul.dickson_VA
Inge,
I saw that you discussed the rear brake pedal wiring via two-pole connection. While reassembling the bike I have lost the connection for the switch. Looking at the book it shows a connection that is tied to the frame (below the seat). I must have tucked it away and can't see it. Do you know where the connection is that comes directly from the switch (brake pedal)? Thanks.
Paul
svlwolf
svlwolf
Does anyone have a good photo of all the rear brake components still attached to the inside of the right footplate bounce
1985 K100RS amidst customization bounce
Rear brake light switch - a senior moment Usa-lo10
HERE is a later model than yours.....most similar, exept switch and peg plate.
