1Back to top Go down   Swingarm bearing K100 rs Empty Swingarm bearing K100 rs Tue Sep 30, 2014 10:01 pm
Flip2
Flip2
On my first attempt at removing one of the bearings from the swing arm, (without penetrating oil, heat/cold treatment), the inner parts came out by themselves leaving the outer ring in the swing arm. i believe i will use a proper slide hammer if i ever have to do that again.
anyway, after getting the stuck part out of the swing arm and inspecting everything i realized that the little plastic bearing holder cracked in three places.
however i was able to get everything back together with new grease and it seems to be smooth rolling.  so would it be okay to use this bearing even though that retainer is cracked?
2Back to top Go down   Swingarm bearing K100 rs Empty Re: Swingarm bearing K100 rs Tue Sep 30, 2014 11:48 pm
I have put them back together a few times like that and never had problems.
3Back to top Go down   Swingarm bearing K100 rs Empty Re: Swingarm bearing K100 rs Fri Oct 03, 2014 9:40 am
Flip2
Flip2
thanks Rick, thats sounds great to me. the bearing still felt fine after it was put back into the swingarm so i will use the old one.
