1Back to top Go down   FAG Wheel Bearing for K100 Empty FAG Wheel Bearing for K100 Mon Jun 08, 2015 12:05 pm
sj2000
sj2000
Found this FAG wheel bearing cheap from Amazon.com, is this the right replacement for 1985 K100? thanks.
FAG Wheel Bearing K100
2Back to top Go down   FAG Wheel Bearing for K100 Empty Re: FAG Wheel Bearing for K100 Mon Jun 08, 2015 12:17 pm
25x47x12 (x 2) is the size of both front wheel bearings for your model, also commonly known in the industry as 6005-2RS. The criteria are met by your posting of the Amazon sale. If it's truly a FAG product, not a (sub-standard grade) knock-off brand, then you're golden!
3Back to top Go down   FAG Wheel Bearing for K100 Empty Re: FAG Wheel Bearing for K100 Mon Jun 08, 2015 1:53 pm
sj2000
sj2000
Ok, I bought 2, thanks.
4Back to top Go down   FAG Wheel Bearing for K100 Empty Re: FAG Wheel Bearing for K100 Mon Jun 08, 2015 2:33 pm
I often find that any good local bearing/seal shop will stock these very common sizes for $8 to $12 each in brand names. BMW would sell you that part number (36 31 1 450 459) for US$22.59 plus tax, each.
5Back to top Go down   FAG Wheel Bearing for K100 Empty Re: FAG Wheel Bearing for K100 Fri Jun 12, 2015 9:01 pm
sj2000
sj2000
the order arrived today, it says made in Korea.
