1 K1100 upgrade Tue Dec 09, 2014 2:00 am
Packo
I am in the preparation stage for this task
It is my intention to swapout the K100 for the K1100. The K1100 will be using the motronic computer, 1100 coils, TB’s, TPS, plugs and injectors. If I use the motronic harness will that take care of all the engine functions and can I then leave the existing relay box, loom etc intact to handle everything else (lights, idiot lights,flashers, clocks etc) ie. the chassis functions.
Am I correct in just plugging the HES wires from the ignition trigger into the plug in the existing K100 wiring under the tank
Do I just unplug and remove the black box (ICU under the tank) or am I simplifying it too much.
Are there any other features on the 1100 that I havent mentioned and need to address and if so how what would you suggest
Mike
Mike
______________
83 K100 HRD Outfit
1992 K1100 Outfit
2003 R1150 GSA Outfit
1983 K100 Basic
