1Back to top Go down   Headlight RT upgrade Empty Headlight RT upgrade Mon Jan 13, 2014 2:10 pm
Had my first burnout with the K, too bad it was the parkinglight.
Placed a 20W lamp, too hot to handle.
First took the electric windscreen off, and the plastic on the inside.
Took away the horms, and the plastic under the fairing, in between the forklegs.
Took away the 3 screws from the case, and found a way te get the case out of the fairing.
Also removed the instrument cluster, but had to go anyway, replaced lights for leds.
Using white/blue leds gives a nice bright shine on the instruments.
Back to headlight;
Removed the clips to remove the glass.
Then took everything apart, cleaned the glass and housing.
The inside of the housing became white, remembered someone here did that before (Charlie?)
Had 4 ledstrips, used 2 of them (6 on the strip) and placed them in the housing.
Found another (white?) led usefull for the original parkinglight.
Used white siliconcrap to keep the strips in place, and fill the holes for the wiring.
Placed all parts back, and back in the fairing.
Headlight RT upgrade 1011857_703377859686454_1902079184_n
Headlight RT upgrade 1505393_703377869686453_1093613914_n
Headlight RT upgrade 995283_703377993019774_1438908661_n
White housing..... What a Face
Headlight RT upgrade 1014017_703378026353104_1940674116_n
Watch the LEDs when off
Headlight RT upgrade 1526620_703377999686440_330709409_n
LEDs on, but blinding the camera
Headlight RT upgrade 1525683_703378086353098_562566806_n
This is more reality, the no-name "daylight" bulb fits best with the LEDcolors.
Headlight RT upgrade Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
2Back to top Go down   Headlight RT upgrade Empty Re: Headlight RT upgrade Mon Jan 13, 2014 2:50 pm
For the LEDstrip, I chose this cheap bugger;
Headlight RT upgrade 1530527_703385913018982_522807836_n
Threw away the housing and the glass, kept the strip with wiring;
Headlight RT upgrade 1507135_703386209685619_1291233026_n
And as bonus a little help with LEDs;
Headlight RT upgrade 1506664_703394879684752_202044246_n
Just an example, I have/there are LEDs in different colors, white, green, blue, red, yellow etc
Use LEDs in the instrument cluster to light up, clock maybe too, NOT to use LEDs in the warning lights, it's too bright.
