1Back to top Go down   Do I have to Drain Coolant? Empty Do I have to Drain Coolant? Tue Aug 12, 2014 9:53 pm
Finnigan
Finnigan
I need to remove my right engine case (cracked) but noticed the coolant hose runs through it.  Do I need to drain the engine coolant before removing the hose from the radiator?
1990 k100LT
2Back to top Go down   Do I have to Drain Coolant? Empty Re: Do I have to Drain Coolant? Tue Aug 12, 2014 9:57 pm
Yes.
You could just drain it by removing the bottom clamp on the hose first and draining it that way.
3Back to top Go down   Do I have to Drain Coolant? Empty Re: Do I have to Drain Coolant? Tue Aug 12, 2014 10:25 pm
Finnigan
Finnigan
Good idea, thanks
1990 k100LT
