FreebasserSF
FreebasserSF
It seems like a lot of times in order to do something, even minor, you have to access the interior of the frame, and in order to get good access you must often take off the gas tank and sometimes the radiator. The fuel has already been covered thoroughly; you put a rag around the fuel lines loosen clamps and electrical, and remove tank from hoses and bike. But for the radiator, I've had to do it over and over in order to deductively determine problems and I've found that developing a system for emptying the bike of good coolant you will use later and then put back in is a useful quick thing to be able to do in order to perform routine maintenance on . I would hope anyone would give advice if a more common sense way is found, because I only want to be a better mechanic. I found that a 5 gallon jug of water with a nozzle and a spot cut in it for coolant to drain into is the perfect height for draining and catching all coolant, and then later putting back into the system. This allows to easy access to the electrical under the gas tank, the air filter and airbox, flushing the radiator or changing coolant, servicing the carbs, fuel system and/or spark plugs, replacing a temperature sensor, coolant hose, or water/ oil pump.
Temporarily Draining the coolant to operate on system and use coolant later  Img_1813
Temporarily Draining the coolant to operate on system and use coolant later  Img_1814
You can close the flap to prevent dust and debris from entering the coolant and easily fill the radiator back up with it and a funnel.
Steve75
Steve75
That's a great tip. Thanks.
Steve
G,day from Oz Temporarily Draining the coolant to operate on system and use coolant later  502531
Good tip Freebasser wish I'd thought of that
Same here, RT. Thanks Freebasser. I can't remember the number of times I emptied and filled the cooling system last year when trying to debug an overheating problem. I used an oil drain pan to catch the fluid and transfered to a jug (via funnel) for pouring back. What a PITA that was. Your idea is excellent; obviously you already have earned your mechanic's badge.
Oldgoat
Oldgoat
Nice tip & great pics! Cool
col
col
great tip
seal with race tape and crap will get in
1991 k100lt "the enterprise"
caferacer62
caferacer62
Sometimes the the obvious solution eludes us until someone comes along with a nice simple way of doin things...thanks for the tip freebaser. Very handy indeed.
Bert 2.0
Temporarily Draining the coolant to operate on system and use coolant later  170874
