1Back to top Go down   New suspension front and rear Empty New suspension front and rear Mon Jul 28, 2014 4:57 pm
ArbOl
ArbOl
Hi all. Time to renew coils - any thoughts on the latest best UK buys?
Preferred forum suppliers RAM has a rear shock for £270 odd.
http://www.realmengineering.com/page15.html
Hyperpro do a front and rear spring package for just £201. However, they don't supply the damper, hence the conundrum.
http://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=40&Ct=MA&SbCt=BA_15_40_MA_70&spPage=3
Riding around on a pogo stick fore and aft makes this an urgent investment!
2Back to top Go down   New suspension front and rear Empty Re: New suspension front and rear Mon Jul 28, 2014 7:06 pm
Snod Blatter
Snod Blatter
How about joining the 21st century and fitting cartridge emulators to a pair of late K75 Showa forks? Or if you've got the Marzocchi cartridge forks (16v) can Gold Valves or similar be fitted? I've not seen anyone here mention these things yet, it's always the same old antiquated progressive springs and thicker/more oil advice. Just a thought.
Alternatively Motorworks and Moto-bins sell pairs of progressive springs for cheap. Can't help with the shock though, I've not had to learn about those just yet..
3Back to top Go down   New suspension front and rear Empty Re: New suspension front and rear Mon Jul 28, 2014 7:34 pm
Race Tech offer Gold Valve cartridge emulator kits for later K Showa forks under part number FEGV S3801 at US$170+, and progressively wound springs under part number FRSP S3234 at US$115+.
http://racetech.com/ProductSearch/2/BMW/K%2075%20all/1992-95
Quality, multi-adjustable shockies are readily available from any number of trusted builders like EPM in New Jersey USA (purveyors of HyperPro, Wilbers, etc.) and Elke, Progressive, Hagon and RAM all make rears available.
Stay well away, however, from Ikon as the original Koni "moulds" must be very old indeed. I have had to enlarge the mounting holes on Ikon shocks for BMWs to allow clearance for the very standard OEM bolt. They are simply built cheaply, lacking in any feel of quality at all.
4Back to top Go down   New suspension front and rear Empty Re: New suspension front and rear Tue Jul 29, 2014 1:55 pm
Snod Blatter
Snod Blatter
In the UK YSS PD Valves are much easier to find than Racetech's emulators, cheaper too at under £100 though it's still a massive rip off for what they are.
Sad to hear about Ikon Crying or Very sad
5Back to top Go down   New suspension front and rear Empty Re: New suspension front and rear Tue Jul 29, 2014 2:02 pm
Kyle10
Kyle10
It's my understanding that you install either the cartridge emulators or the progressive springs, but not both.
Correct me if I'm mistaken (it has happened in the past, believe it or not).
1985 K100rt 0052183
1983 Honda VF750 007713
6Back to top Go down   New suspension front and rear Empty Re: New suspension front and rear Tue Jul 29, 2014 2:09 pm
Snod Blatter
Snod Blatter
You can absolutely install both, though linear springs seem to be more highly regarded (fashionable) at the moment than progressive springs as they make setting up the emulators a bit easier, being constant. The springs do what they always did, they hold the bike up off the ground, while the emulators take over the job of damping from the holes in the damper rod by acting as a valve, not opening much most of the time (giving a harder ride with less wallowing/dive) but being able to open a lot if necessary, thereby trying to smooth things out when you run over a stone or a speed bump or whatever. I say try as I don't think they are properly amazing but they're certainly better than your average damper rod setup.
7Back to top Go down   New suspension front and rear Empty Re: New suspension front and rear Tue Jul 29, 2014 2:11 pm
Kyle10
Kyle10
Thanks, Snod. Might give the emulators a go as I've already have the prog. springs.
1985 K100rt 0052183
8Back to top Go down   New suspension front and rear Empty Re: New suspension front and rear Tue Jul 29, 2014 2:15 pm
Snod Blatter
Snod Blatter
Beware you'll have to modify the damper rod with more holes to stop it from damping, it's a one way process! This is also purely for the Showa forks, the Sachs forks are too weird for this kind of thing..
