mhsilverw
mhsilverw
After a few hundred miles since getting the 1985 K75C back on the road have noticed a spot of oil on the garage floor below the clutch arm, and there seems to be a rubber boot there. I am thinking it may be leaking from there and wonder if this is split or perished with age.
Is this easy to replace any hints or tips?
If there is a leak here is that an indicator of anything major?
My Haynes manual doesn't seem to be very descriptive about replacing this other than to if its leaking.
Mark
First check that the clutch is correctly adjusted, if the lever arm at the gearbox have to much angle relative to the piston/rubber boot, a leak could occur.
How to adjust the clutch correct.
mhsilverw
mhsilverw
Inge K. wrote:First check that the clutch is correctly adjusted, if the lever arm at the gearbox have to much angle relative to the piston/rubber boot, a leak could occur.
Clutch adjusted correctly..cable length at end and free-play; and still a drip from that area.
Any notes or hints on the steps to replace the rubber boot?  Embarassed
Should any other parts be replaced at same time  Question
Is this 'easy' with the engine/clutch/transmission in the bike or is there some major dismantling   😕   needed?
Mark
walfish
walfish
Can be done without removing any bits.
Things to check would be the thrust bearing inside the rubber boot on rear of the the pushrod also check the clutch arm bearings for wear.
I did mine recently, instead of a clamp to secure the boot I used a (black) cable tie pulled up really tight, so far no leaks.
Can be a bit fiddly though.
 K75C clutch pushrod seal/rubber boot. 22936
K75C clutch pushrod seal/rubber boot. Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
