1Back to top Go down   Clutch actuation pushrod seal Empty Clutch actuation pushrod seal Tue Mar 20, 2018 3:41 am
@kustom_moto
@kustom_moto
Clutch actuation pushrod seal Screen10Guys I cannot for the life of me work out where this pushrod seal in the image from the motorworks website goes. Does this fit into the rubber boot?
2Back to top Go down   Clutch actuation pushrod seal Empty Re: Clutch actuation pushrod seal Tue Mar 20, 2018 4:10 am
The push rod goes down the middle of the main shaft and that seal goes into the main shaft end to prevent oil running down the shaft onto the clutch.
When you look at the seal which is in there the first instinct is that some fool put it in backwards but not so.  The inside of the seal which has a tiny coil spring around the centre lip should face towards the rear of the bike.
3Back to top Go down   Clutch actuation pushrod seal Empty Re: Clutch actuation pushrod seal Tue Mar 20, 2018 5:10 am
@kustom_moto
@kustom_moto
Ok great thank you. Does this mean it is situated in here?
Clutch actuation pushrod seal 20180310
4Back to top Go down   Clutch actuation pushrod seal Empty Re: Clutch actuation pushrod seal Tue Mar 20, 2018 6:27 am
The little clutch pushrod seal is a tricky bugger. Get it wrong and it ends up inside the gearbox. Disassemble to remove. Try to avoid replacing it if you can.
5Back to top Go down   Clutch actuation pushrod seal Empty Re: Clutch actuation pushrod seal Tue Mar 20, 2018 7:42 am
Paul75 wrote:Ok great thank you. Does this mean it is situated in here?
No the other end of the shaft at the rear of the transmission.
6Back to top Go down   Clutch actuation pushrod seal Empty Re: Clutch actuation pushrod seal Tue Mar 20, 2018 8:41 am
@kustom_moto
@kustom_moto
Great thanks guys!
7Back to top Go down   Clutch actuation pushrod seal Empty Re: Clutch actuation pushrod seal Tue Mar 20, 2018 8:42 am
Take a look at this link, Paul.
8Back to top Go down   Clutch actuation pushrod seal Empty clutch rod seal Tue Mar 20, 2018 1:08 pm
brickrider2
brickrider2
I just went through this with my airhead. That seal can indeed be tricky.  The very tiny spring came off mine when I had the transmission on the bench.  I didn't work out where the spring had come from until I had all the bits reassembled  Mad  Now the seal is in place, sans spring.  The good news is that I haven't oiled the new clutch disk - yet.
