1 Spoked wheels on K1100 Thu Aug 21, 2014 4:48 pm
Konstantin G.T.
Because spoked wheels much better
Last edited by Konstantin G.T. on Fri Aug 22, 2014 6:03 am; edited 1 time in total
I didn't understand last comment. What do you mean talking about original pinion gear? I left gears from K1100LT , I changed only finel drive's cover....Two Wheels Better wrote:
Let's hope that behind the scenes some effort was made to measure and shim the replacement ring gear with the original pinion gear otherwise we'll have a well and truly fragged final drive on about the second or third short ride.
Thanks for that.
Looking at the video, Konstantin removed both covers with their respective ring gears intact. He then removed the ring gear / bearing assembly from the old K1100 cover and swapped it into the R1100GS cover. Shimming of the pinion may not be necessary if the bearing holes on both covers are precisely the same relative to the K1100's final drive case. It's probably not a bad idea to check the clearance on the pinion gear using the process described on page 33.15 in the BMW K1100 service manual, just to have peace of mind.Two Wheels Better wrote:My apologies, I must have been mistaken. I thought I saw a different ring gear being swapped into the final drive to mate up with the pinion gear. It must have been a language barrier. I'll have another (closer) look at the video.
Nice modification.
Cheers.
Wow, nice!! Certainly a very rare view of how this part of the motorcycle is designed and constructed. Very educational. Thank you for posting Konstantin.Konstantin G.T. wrote:Fuel tank from the inside
Have in mind that this "breather box" have been changed at least two timesRicK G wrote:
I am looking at combining 2 tanks to make a bigger tank for the K75 GS I am building.
It's doable, Floyd, but you will need the Marzocchi forks, 305mm brake discs, four piston callipers and 20mm m/c from a K11 to fit a 19" front wheel to your earlier model. The calliper mount spacing holes and the offset are quite different from 8V to 16V models. But out in the Red Centre on a dusty track a 19" spokie with knobblies would lead the way for sure!floyd wrote:I will certainly be doing this to my bike. When the current front tyre wears out ill try and source the 19'' rim with rotors.
Konstantin G.T. wrote:Not so much. But something.
Similar topics
