1 ignition breakdown Mon Apr 14, 2014 6:50 am
chris.edwards2
Riding home a few nights back on my '82 K100rs I had a total breakdown and cannot find the problem. The bike was running particularly well (of course) and then ignition totally dies while travelling at 60mph. Ignition lights and head lights remained on. Tried to restart but no cranking at all. Tried to bump start as on hill but no ignition (I presume).
AA arrived and we went through every connector we could find - no luck. Finally on low loader at 2:30 am. Engine will crank when battery applied direct to starter. Replaced the load shed relay as I had a problem last year with headlight remaining on and thought it may be connected. No fix.
Fuel relay clicks when pressing start button. Looked at wiring diagram and it looks like the starter solenoid is earthed through ignition module which makes me suspect the module has gone wrong - is this too simple thinking? Voltage at switch side of the solenoiud is only 9V? Curious. Fuel pump does not come on when turning on ignition.
So basically engine will not crank through Start switch and no ignition. Any suggestions on what to check next much appreciated
Chris
p.s. The alternator light had glowed fairly brightly 10 miles previously, but had gone out.
Chris
