1Back to top Go down   Hole in Headlight Lens Empty Hole in Headlight Lens Tue Mar 11, 2014 10:39 am
One of the bikes here has a hole in the headlight lens from a stone. I found out today that it will fail the roadworthy because of that and I need that roadworthy certificate to sell it.
Has anyone tried getting a windscreen repair guy to fix such a hole and did it work?
Sounds a lot easier than sourcing a new lens and pulling the stinking fairing off.
2Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Tue Mar 11, 2014 12:49 pm
FYI: You don't need to pull the whole fairing off to replace a headlight lens.
3Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Tue Mar 11, 2014 3:47 pm
klamityboy
klamityboy
Slightly off topic but related. Does anyone know where to get a headlight protector for the square RT headlight? Have seen them on bikes and pictures but never could find out a source.
Klamityboy
1991 K75RT-P
Model Description: K 75RT
Market: Europe
Type: 0565
E-Code: K569
Engine: 3_ZYL - 0,70l (55kW)
Transmission: Manual
Body Color: Polizeiweiss
Production Date: 30.08.1990
4Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Tue Mar 11, 2014 3:49 pm
5Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Tue Mar 11, 2014 5:12 pm
klamityboy
klamityboy
Thanks. Is the K75RT headlight the same as the K100RS?
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
6Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Tue Mar 11, 2014 5:25 pm
Yup.  Both the "bucket" and lens are the same part.
7Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Tue Mar 11, 2014 5:29 pm
klamityboy
klamityboy
Perfect. Thanks
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
8Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Tue Mar 11, 2014 7:36 pm
Mike101
Mike101
klamityboy wrote:Slightly off topic but related. Does anyone know where to get a headlight protector for the square RT headlight? Have seen them on bikes and pictures but never could find out a source.
Have a look on eBay.  I got for for £20 just today.
Mike
K100LT 1987 Gold and not Beige
XT660Z Tenere
9Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Tue Mar 11, 2014 8:00 pm
RobinW wrote:One of the bikes here has a hole in the headlight lens from a stone. I found out today that it will fail the roadworthy because of that and I need that roadworthy certificate to sell it.
For the R, I presume or bowling ball as you put it.  Give O'Brien Glass a ring but I reckon it could be done.
10Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Tue Mar 11, 2014 8:20 pm
Rang RACQ screen repair Rick, they inject resin so it will flow into the lamp, no good. Tried a window tint mob for 3m clear protective film over the lamp but they say it's not weatherproof and has to go on the inside. The roadworthy rule says there can be no way for dirt/water to enter the lamp and the beam must be clear of defects so I'm tossing up between either clear silicon or a glass repair kit. The hole is off to one side, out of the beam. I should have had a protector on it.
11Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Wed Mar 12, 2014 12:56 am
I used a thick self adhesive protective headlight cover material years ago for some lights.  Was meant for the outside.  At that time i got it as a kit at k-mart.  no idea if it's still available.  1 universal car kit was good for 2 bikes at least.  Saved maries headlight from a direct hailstone hit in one of those big hailstorms we get from time to time.
'93 K1100LT
Hole in Headlight Lens K-dogs10
12Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Wed Mar 12, 2014 3:03 am
The LT has a protector, never got around to putting one on the RT. It got holed on the run to Kingaroy around xmas, I just ignored it.
I found some araldite ultra clear epoxy glue and bogged up the hole. It's for glass and sets clear. I'll slip into the bike shop next time I pass and ask if it'll do.
13Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Wed Mar 12, 2014 5:13 am
Hey Robin, why don't you take the bike to wherever you take your car, for a rego check. The bike shop will be trying to find some work, where the standard rego bloke will just make sure all the lights ect work, he wont be interested in finding things he can do on the bike .
14Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Wed Mar 12, 2014 5:19 am
+1 to what Smithy said.  I never take the bike to a bike shop for checking, they always find something.  The local car workshop is OK, though he starting to get very picky with the sidecar and it's lack of engineering docs.
'93 K1100LT
15Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Wed Mar 12, 2014 5:24 am
Robin,
This bloke comes recommended to me as a mate used him recently for a Laverda.  So you could say he knows older bikes. Has a mobile service and located at Kingston.  I will phone him when the RT is ready for rego.
3W.motorcycleroadworthys.com.au
Dave.
16Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Wed Mar 12, 2014 5:47 am
My old neighbor from about 3 houses ago runs the workshop at southside suzuki. I get a RWC done there for $42 and none have failed yet and they take them for a ride Smile  Car places can't do bike roadworthies in queensland, they aren't certified. Already tried that with one of my customers. The guys that come to your house charge $120, been there, done that. But if Andrew says he can't pass it with a holed light I'll get the guy to come here, he just walks around them. Last time he was here for the boys old suzuki he didn't even turn the ignition on  :suspect:  All 3 bikes here need roadworthies, maybe the guy that comes to you can do me a deal Smile
17Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Wed Mar 12, 2014 10:18 am
Try the auto parts stores, they should have a resin to fill the glass, the diy kits may not be as good but to pass rego, may be all you need
18Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Wed Mar 12, 2014 10:30 am
Twas $32 for one of those DYI kits and they are aimed at cracked windscreens. This ultra clear araldite is a 2 part epoxy, was $13 and there's 100 times more of it Smile
Too late now it's in there and it's set  Twisted Evil
19Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Wed Mar 12, 2014 10:33 am
TacKler wrote:Robin,
Dave.
yeah dave thats the same guy that came to put gerty on the road
sensible sort of chap
20Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Wed Mar 12, 2014 10:45 am
If you got an unregistered bike here Charlie, you download and fill in the forms for rego, get a Third Party insurance certificate from any RACQ office and now you can ride your bike without plates to a RWC center, then to transport and register it. It's a lot cheaper Smile
21Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Wed Mar 12, 2014 10:49 am
RobinW wrote:Twas $32 for one of those DYI kits and they are aimed at cracked windscreens. This ultra clear araldite is a 2 part epoxy, was $13 and there's 100 times more of it Smile
Is it really ultra clear?
22Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Wed Mar 12, 2014 10:53 am
I've never seen it before, it's ultra clear tonight, not sure about 6 months time, that's not my problem Smile
I could only smear it over the front anyway, the actual bullet is on the inside, sort of reverse to a windscreen divet.
There are 2 headlights on ebay .au if push comes to shove but they both want $199. There's a Ducati twin headlight to fit my ST2 on there for $50 so $199 seems a bit off the planet.
23Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Tue Apr 01, 2014 2:50 am
Just to close this off, I took the Ducati down for a $45 Safety Certificate today and my mechanic mate said that so long as the headlight doesn't have a hole in it, it will be fine. I told him it had been patched with resin and he recons it's not an issue for the RWC.
The RWC guy that comes to you wanted $220 to do all 3 bikes. I'll just ride them to Sprimgwood one at a time as needed for $45 each.
24Back to top Go down   Hole in Headlight Lens Empty re mobile rwc Tue Apr 01, 2014 3:22 am
Garyk100
Garyk100
sounds like the same mobile guy up here in Redcliffe, quoted $70, said the tyers were shot when he came out, I still had 3 to 4mm of tread, but the bike had been sitting for 3 years, so the donuts would be stale and hard,so as soon as it was regoed I was getting a set of angels, they were at the bike shop a few ks away, as we dont have a bike shop local, anyway after many phone calls to his girlfriend and sitting in his ute, I was told if I wanted the safety cert it would be $120. yeah I paid it, after 3 years I was needing to ride, was regoed that afternoon, it was then I was told, pay the 3rd party ride it to the bike shop and get the tyers and safety cert, could of saved a few bucks,
25Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Tue Apr 01, 2014 3:48 am
When you rego a vehicle in Queensland all you need to do is get the third party insurance and put the rego on the same day then taking it for roadworthy etc you are covered.
26Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Tue Apr 01, 2014 4:51 am
Insurance, completed rego forms, ride to RWC then ride to rego, too easy.
If it fails RWC you can get the date/time changed on the insurance without an issue.
They didn't even want to see my bill of sale today.
27Back to top Go down   Hole in Headlight Lens Empty Re: Hole in Headlight Lens Tue Apr 01, 2014 12:34 pm
Kyle10
Kyle10
Mike
Off-er topic but related. Perusing eBay for a headlight protector and came upon this.
Marketing is so very crucial these days...
1985 K100rt 0052183
1983 Honda VF750 007713
