1 Gremlins Fri Mar 07, 2014 1:51 pm
nino
Hi everyone,
problems started as little disturbance between 1500 - 2000, more like hesitation. From 2000 pulled strong as usual.
After that no start at all, even with good battery, ignition coils&wires and spark plugs. Suddenly that dissapeared, engine started every time but not at once as usual. When hit button iz spins and spins and finnaly fire up. While runing same problem from begining hesitation on 1500 - 2000.
What to check. I cleaned most of contacts already.
P.S. I opened relay box maybe half an hour after ride and discovered only load shed relay was still hot. Does it mean anything?
Regards
Regards
