1Back to top Go down   White indicator lens Empty White indicator lens Thu Sep 12, 2019 2:43 pm
Davep
Davep
Hi all
There was some discussion on here a little while ago about indicator lens, so I thought I would post a pic of my RS with the white lens fitted. I personally think it looks a little anaemic and could do with some colour but cost over legal requirement and the need to put fuel in meant I couldn't justify close to £50 per lens, these were £40 for the lens and bulbs, I do however think they should include new screws as these could be lost (mine weren't).
Anyway, here's a pic of white lens on a light blue RS.
White indicator lens Lens11
White indicator lens Eu-log10BMW K100RS 1983 (Main ride)
                      Suzuki GSX 750 ET 1979 (Needs work)
                      Kawasaki Zephyr 750 1992 (Needs hiding)
2Back to top Go down   White indicator lens Empty Re: White indicator lens Thu Sep 12, 2019 4:39 pm
Avenger GT
Avenger GT
Did you change the bulb holders? Amber bulbs have a different locating pin configuration to clear bulbs.
3Back to top Go down   White indicator lens Empty Re: White indicator lens Thu Sep 12, 2019 4:52 pm
looks good dave
what I have done also
4Back to top Go down   White indicator lens Empty Re: White indicator lens Thu Sep 12, 2019 4:58 pm
Davep
Davep
No, they just swapped straight over. I just had a quick look at the old ones and they are the same bar the colour, I don't know if they have been changed prior but both bulb ends are identical.
Dave
5Back to top Go down   White indicator lens Empty Re: White indicator lens Fri Sep 13, 2019 1:40 pm
Avenger GT
Avenger GT
Davep wrote:No, they just swapped straight over. I just had a quick look at the old ones and they are the same bar the colour, I don't know if they have been changed prior but both bulb ends are identical.
Dave
O.E. amber bulbs don't have the locating pins at 180 degrees, they are offset at about a 150/210 degrees. Of course a quick look on the Googly search revealed that they are also available with 180 degree pins. Another bit of information added to what's left of the old memory, probably replacing something more important that I've already forgotten.   Smile
6Back to top Go down   White indicator lens Empty Re: White indicator lens Fri Sep 13, 2019 2:53 pm
Davep
Davep
I didn't know they were different, I must have just been lucky, although I would have been proper annoyed if they hadn't fitted. I'll have to remember that when I need spares.
Thanks for the heads up.
