1Back to top Go down   O rings injector Empty O rings injector Fri Feb 28, 2014 1:04 pm
nino
Hello all. I have to change injector O rings cause of air leaks. Somebody told me that K 100 Le Jetronic use special O rings with special dimensions. My question is may I use other O ring for example from Opel with LE Jetronic which I can find in  neighborhood. What is dimension of O ring?
Regards
2Back to top Go down   O rings injector Empty Re: O rings injector Fri Feb 28, 2014 1:26 pm
japuentes
japuentes
Hi there, I use the standard o rings for car applications using the same type of injector.
Best regards
JAP
O rings injector 2854237993 1988 K100RS SE/ABS
3Back to top Go down   O rings injector Empty Re: O rings injector Fri Feb 28, 2014 4:35 pm
agree jap
yes nino the car ones fit properly
we (me and the aussie mates ) have bought several sets and all good
4Back to top Go down   O rings injector Empty Re: O rings injector Sat Mar 01, 2014 5:20 am
Hey Charlie,
Where do you buy yours locally?
I have been buying a few things in bulk locally, for future use as one day some of our spares may become scarcer to obtain.  So far I have sourced aluminium crush washers, the hall effect sensors and I see that fuel pumps, oil filters and other items are available locally if you know where to look.
If I remember correctly the BMWMOA has a list of Bosch items suitable for K series.
I am wondering if it would be suitable to start a thread of locally sourced items (with prices) so that we can save a bit of leg work.  The aim would to be to get the cheapest price of consumable items for K biKes, complete with dimensions, reference numbers and price.
Last year I spent a considerable sum of money on a selection of stainless steel fasteners.  The reason?  As I own five Be Emms now, (actually five and a half) I find it easier to have spares on hand, instead of extending the mortgage each time I head to the dealer to replace one or two items.
Open for thoughts, I am sure others have been down this track before me.
Cheers, Dave.
5Back to top Go down   O rings injector Empty Re: O rings injector Sat Mar 01, 2014 5:53 am
there was a post a while back now ...
cant find it .....but in essence there was a guy out of Melbourne selling kits for 4 injectors at a time from memory
they were for ford injectors . included the pintle shield , spacer and 2x o rings per injector ....$20 aussie for the kit ...plus some really small postage (was about the time of the workshop day up in Kingaroy  a year or 2 ago )
ill try and find it again ....but I have changed operating systems since then ...and lost a lot of stuff in the process ....dang !!!
6Back to top Go down   O rings injector Empty Re: O rings injector Sat Mar 01, 2014 6:12 am
Ghost who rides
Ghost who rides
That is a good idea Tackler, in theory.
From my limited experience however, when someone posts up a part at
X price, someone else says Ebay da da d[size=12.800000190734863]a for x cheaper, or part  from [/size]
X is better than Y. In the subject of this thread, injector o rings,
Bosch being the first (arguable?) and certainly the biggest/most
made, many many companies have copied /produced kits to suit.
Do you go genuine Bosch with unquestioned quality or aftermarket
as I did? Did I save much Dollar wise?
It's like tyre or oil threads, everyone has an opinion!
But yes Tackler let's get it started. We need someone who is in rehab
from an operation, with time on their hands, superior Knowledge of the
Bricks in all their variants and whose name starts with R Very Happy
Did you notice my first ever use of an Emoticon?
Just joking R Very Happy
Last edited by Ghost who rides on Sat Mar 01, 2014 6:14 am; edited 1 time in total (Reason for editing : Some crap size and numbers appear above as if from.. the internet)
7Back to top Go down   O rings injector Empty Re: O rings injector Sat Mar 01, 2014 7:13 am
nino
Result: I found some new O rings in Opel workshop, mounted on injectors and rail and push all together to cylinder head. Started engine and check for leaks with deoxit. Cylinders 1,2,3, leak, cylinder 4 not.
Than found a thread here in portal: Inge wrote dimensions of O ring; 7.52 x 3,53! Friend of mine who is BMW mechanic told that O ring for K has slight differences than for cars with same LE jetronic. (7,52 - 3,53). So I decided to wait original O rings which he will send on Monday.
Regards
8Back to top Go down   O rings injector Empty Re: O rings injector Sat Mar 01, 2014 1:39 pm
good feedback nino ...thanks
will check again ...but for many of us the fit was without leaks as the vacuum sticks synchronising was achieved well
have some real bmw parts as well,  must measure them  and compare the ones we have been getting  pitty they are up in Kingaroy with Alby
9Back to top Go down   O rings injector Empty Re: O rings injector Sat Mar 01, 2014 2:27 pm
nino
Charlie, as I understood difference is that K O ring is 3,52 mm - 7,53 mm, but other (car) aplications 3,5 mm - 7,5 mm. My friend mechanic highly reccomended K O ring, because of extended period of use. I head a general type rings on my bike, but it started to leak after cca 3,5 years, so this time I ll put original.
10Back to top Go down   O rings injector Empty Re: O rings injector Sun Mar 02, 2014 12:38 pm
japuentes
japuentes
Hi there, as far as I know all applications (both cars and MC) using Bosch injectors uses the same o rings.
Audi/Bosch systems uses a different injector and o ring, there are also other brands.
Bosch o rings are 3,52 mm - 7,53 (nominal, if you measure them you'll find minor deviations) this is an odd size, perhaps due to commercial reason. If you use a common o ring, most probably you'll have a leak.
Go here they have good info.
Best regards
JAP
11Back to top Go down   O rings injector Empty Re: O rings injector Sun Mar 02, 2014 2:08 pm
nino
japuentes wrote:Hi there, as far as I know all applications (both cars and MC) using Bosch injectors uses the same o rings.
Best regards
JAP
Thanks for link: its Bosch 203
12Back to top Go down   O rings injector Empty Bosch 203 Tue May 06, 2014 8:17 pm
sherpaguy
sherpaguy
Does anyone have a set of those o rings - bmw here in Canada wants $ 7.67 each plus taxes. A little rich me thinks
13Back to top Go down   O rings injector Empty Re: O rings injector Tue May 06, 2014 8:37 pm
Check out Mr Injector on ebay.
Might not have specific for K100 listed, but he sells a complete kit for cheap.
14Back to top Go down   O rings injector Empty Re: O rings injector Tue May 06, 2014 8:38 pm
sherpaguy
sherpaguy
Will do
15Back to top Go down   O rings injector Empty Re: O rings injector Tue May 06, 2014 9:24 pm
Those O-rings are common to a great many of the Bosch injectors and other brands so are usually available from auto shops
16Back to top Go down   O rings injector Empty Re: O rings injector Wed May 07, 2014 11:31 am
japuentes
japuentes
Hi there, try rockauto.com, I know for sure that 1998 Jeep Cherokee o rings are the same on my K.
Set costs less than 4$ and you'll have spares.
Hope this helps
Best regards
JAP
