![avatar](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
![Life time member Life time member](https://i.servimg.com/u/f80/11/71/56/74/bmw-5s10.gif)
Number of posts : 7942
We have all broken one at some point so you shouldn't beat yourself up over that, can happen anyone. At least it means its not an engine related problem. Going back to the Lambretta, as a two stroke and cast iron liner the characteristics are so far apart it would not be a wise move. Most brick engines never get rebuilt and you don't want to be stripping that one out again.
A bit of shopping around might find an alternative price, or someone here might have a set of rings lying around. But check on your bores, are they standard? As far as I know the very early pistons allowed the rings to rotate freely, they didn't have the little stop that's in all 2 strokes to stop the ring moving around on the piston and catching in the transfer ports. On the K this allowed oil to get past the rings when the bike was parked on the sidestand. I believe later ones do have this as a means of reducing the blue smokey start up. I am not recommending putting in a used set of rings but I would have more faith in that alternative than using the Lambretta option.
1971 Yamaha 125 YAS-1
