Number of posts : 7963
The later rings will have a little bevel or cut out at the ends to mate with a bridge across the ring groove in the piston. Ring will therefore be slightly shorter to allow for thw bridge so it won't be usable. Two stroke engines always had rings pinned so the ends would not rotate into the transfer ports in the cylinder wall. You only need them on a 4 stroke engine where the cylinder is horizontal. Not sure but I have a feeling the groove dimension may also have changed.
1971 Yamaha 125 YAS-1
