1 automatic starting Tue Oct 29, 2013 12:48 pm
alanretired '85 K100
often when bike is in neutral and I turn the key on the bike just starts up. other times I'll pull the front brake with the bike on and it starts. The start button also works and will also turn the bike off. I don't have an owners manual so I don't know if this is normal.
Would this also have an effect like this? " Since I've had the bike ( a month) I'll be riding then suddenly no power, bike just sputters. bu, bu, bu, bu, bu. Not enough power to move the bike faster than a walk, but it does not die. Turn the throttle nothing. Pulled over turned off the kill switch and back on and runs fine, power back. Both times was about 1/2 tank left. Not sure if that was the problem though as it still ran fine with that much fuel until I refilled."
Is there something in the fuel system that would be about half a tank high that would limit the fuel flow below 1/2 tank?
