1 Spooky start Tue Jul 02, 2013 5:16 pm
gunsports
I've had my K100 for exactly one month now. Last Saturday I decided to do a service on the bike as it has not been serviced for near two years. Oil filter was replaced by BMW OEM part, as was the air filter. I changed all the oils as per spec and also the plugs (NGK D7EA).I noticed that the plugs removed were NGK D8EA's. Plugs were still in a very good condition; if a little sooty. Bike ran beautifully after the service.
On Sunday I filled up with petrol. As the previous owner was at high altitude, he used 93 oct unleaded petrol in the bike. I re filled with 95 oct leaded fuel. Bile still ran well; but I had a puncture (rear wheel) which laid the bike up till today; when the bike shop came to fetch it to repair the wheel.
Just before they collected the bike, I started it up and it struggled to idle. Now normally, the bike idles at just above 1000rpm when warm; but today, even with the choke full on, she struggled to reach 900rpm. Idling was very rough; as if she was only firing on three cylinders. As the bike heated up, idling increased slightly and the engine ran a ittle smoother, but still very uneven; as if one plug was not firing correctly. This unevenness persisted; even when revved to 2000rpm.
Now here is the scary part: The engine, especially when still cold, stuttered and died a number of times and then the starter would kick in and start the bike again - withou me near the bike! This happened three times. The engine would die; the starter kicks in and the engine would take again - and then die and be started again.
When I replaced the plugs, I was carefull about the plug wires. In fact, I replaced the plugs one at a time; so not as to mix up the plug wires. So I doubt if it could be this.
When the bike was on the trailer, I told the shop owner about this and then started the bike again. She started normally and idled smoothly. I did not rev the bike to see if the unevenness would show higher up in the rev range.
Now, I am a noob when it comes to this bike and frankly, what happened this afternoon scares me a little as I do not want to damage the bike through my lack of knowledge.
Any suggestions?
Any suggestions?
