Time for a Kart upgrade .
I have recently added this little set up to the riding experience .
Since our last posting in 2016, Ol' Blue has been retired , and Smurfette has taken on the task of providing a legacy on behalf of our komrade RossKKo.
As i am requiring the need to konvey various equipment to set up a Charity awareness stall , I have upgraded to this little outfit .
The base frame on leaf springs , with 8"inch high speed alloy wheels .
Total width to the outside edge of axle = 1000mm
I found a "Karrite" car luggage pod at my local recycle centre for $30aud ,
the only repairs needed to it , a broken key in the lid lock , costing $15 ti fix , this included 2 new keys .
Size of pod is 1300mm long x 850mm wide x 350mm high.
I have mounted some galvanised C section 50mm x 160mm to the trailer chassis , before mounting the kapsule .
This provides room under the pod to store 3 plastic mould tables .
For the moment it is fitted with an Al-ko pressed steel coupling .
Eventually I would like to swap it over for a swivel hitch .
I can now easily transport all the neccessary gear to help with setting up .
Plenty of room inside the kapsule to carry the 3m x3m gazebo.
