had a good run today , headed down to Woollongong to pick up the
horsefloat dog box.
left home in the early cool hours of the morning. reaching the northern villages of W'gong around 7.30.
the charming beachside arena of Coledale. couldn't resist stopping. Waz is in the midst of some fantastic beaches in the South coast region.
![kart for my K Bulli_10](https://i.servimg.com/u/f57/17/85/21/22/bulli_10.jpg)
whilst scouring the many lookout points , I happened across this one , which is now my preferred retirement location. The VIEWS are to ...............
![kart for my K Bulli_11](https://i.servimg.com/u/f57/17/85/21/22/bulli_11.jpg)
finally made it into town to pick up my dog box , taking the road to the left to get me going right ended up being wrong. wheres that Rossko when you need him ?
some comments from the seller whilst I was handing over some legal tender,
" they are not high pressure tyres , 20- 25 psi should do it. Ali lite made it for me as a dog trailer, all mods including screen , rear door and roof racks are factory fitted.
there is a grease nipple on the hitch , may need some topping up. my first stop 10mins away proved it a definite, the swivel wouldn't budge much.
we travelled with our two german shepherds in that trailer, they loved it."
first thing I checked were the lights , hooked the harness up , all were operational except the left turn signal , proceeded to test the harness on the sellers car , same result.
so my efforts at wiring up yesterday were good. changed some globes around , no difference. so headed home with the least number of left turns possible , I decided the M7 link road back through Sydney to be the safest.
the seller suggested Mt Kiera lookout was closed from the direction I wanted to access it . So Mt Ousley Rd was the next option..
An uphill windy run proved effortless with the 55kg alloy trailer on board. I still remained cautious on my maiden towing voyage.
Mt Kiera lookout was inaccessible , and as it happened , heading up Appin Rd toward the Hume Hway,
signage pointed me in the direction of this little cafe hanging over the side of the cliff.
guess what it is called ......?
you may notice the trailer in a slight up ward angle , it is fitted with a dropped axle , which I may rotate later to level the trailer . this will inevitably raise the centre weight of the trailer , what is best lower or raise? remember there is no load in the trailer as yet. I may even lengthen the towbar hangers by 2 inches?
![kart for my K Bulli_12](https://i.servimg.com/u/f57/17/85/21/22/bulli_12.jpg)
overlooking Thirroul to the left and the Gong to the right in the distance.
![kart for my K Bulli_13](https://i.servimg.com/u/f57/17/85/21/22/bulli_13.jpg)
with the morning heating up a bit , it was time to take the fastest road home.
the only concern whilst heading back to Newcastle ,
was on the downhill to the Mooney Mooney bridge , the bike developed a speed wobble at 110kmh, I steadily eased off the throttle and regained stability.
the K maintained 60kmh / 5th gear @ 2500rpm , 100kmh @ 4000, and 110 @ 4300, so was running sweet.
Couldn't help myself , I turned off the freeway ( now the M1 ) at Mt white for some enjoyment , twisties.
strapped the camera to the roof rack and gathered some
video of the run through
mooney mooney ck .
mind you the highway was abuzz with patrols for most of my trip home, .counted at least 12 using radars , at least 6 on the M7, so I behaved myself
Now to plan the kamper.
thanks for everyones help during wiring up , It made the trip so much easier.
A fresh coat of BMW / Forum graphics to start.
I'll try and keep it simple as , mind you Rendrag has given me some ideas.
will start with putting together 2x 1200 x 1100 boards , hinged , to fold out as a 1200 x 2200 bed base.
temporary ply box lid for waterproofinga couple of alloy adjustable poles for support leg struts for the bed.
stabilizer legs under the rear for when the trailer is parked and in use.
internal ply base with carpet for protection of floor and gear.
donetarp hold down hooks on outside panels for soft cover.
donesomething like
this I'll review some camping checklists similar to 92kk's suggestion and look for lightweight options .
