1 electrical Sun Dec 15, 2013 4:21 pm
tufty666
thanks everyone on the forum for your help and advice. 1 month and 1 day, k100rs back 2 life. its really a tale of going back 2 basics and never giving up. KEEP THE FAITH WITH YOUR K AND YOU WILL BE REWARDED. after changing everything more than once, turned out to b 2 faults. firstly, my pick ups were dead. 1st replacenent 2nd hand pick ups were dead on 1 side, as were the 2nd set i got, and unbelievably, were the 3rd set i got. is it because these things are 20 years old?. also ecu fault. engine would only turn over half a turn. WAS NOT A STARTER MOTOR OR ALTERNATOR FAULT, AS I ALSO CHANGED THE BRUSHES. 4th set of pick ups and a replacement ecu,HEY PRESTO, LIFE. pick up fault meant spark on coils 1 and 4 on all the faulty pick ups i had. no signal from brown top sensor wire. im going to locate 6 2av54 sensors and make up 3 completly new hall sensor plates. should last for a while. going 2 get injectors balanced b4 i take it 4a spin on tuesday. HOT TIP ON ALTERNATOR BRUSHES/REGULATOR. TAKE YOUR COMPLETE BRUSH ASSEMBLY TO YOUR LOCAL GSF DEPOT, GET A NEW ONE FOR £11. SAVE A FORTUNE ON GENUINE PART. also, going 2 look into 4hole injectors. take care all, and HAPPY X MAS AND NEW REAR TO U ALL
