1Back to top Go down   anyone used these? Empty anyone used these? Sun Dec 15, 2013 9:43 pm
KKlompy anyone used these? 2854237993
anyone used these? Au-log10
2Back to top Go down   anyone used these? Empty Re: anyone used these? Sun Dec 15, 2013 9:49 pm
No, but I have a set of those caps at home.
I tried to fix mine up years ago when I saw the price of new was over $300.
So is it the lead that breaks down or the cap?
welcome to try them.
3Back to top Go down   anyone used these? Empty Re: anyone used these? Sun Dec 15, 2013 9:51 pm
looks a reasonable price ...
heres the link for realm engineering
[url=http://www.realmengineering.com/ram power leads.html]http://www.realmengineering.com/ram%20power%20leads.html[/url]
4Back to top Go down   anyone used these? Empty Re: anyone used these? Sun Dec 15, 2013 10:59 pm
I have bought a lot of gear fom EME and all has been good, he does have a good reputation.
5Back to top Go down   anyone used these? Empty Re: anyone used these? Mon Dec 16, 2013 12:07 am
here is a good choice too thanks Charlie...spoilt for choice almost.
Last edited by Klompy the grey brick on Mon Dec 16, 2013 4:32 am; edited 1 time in total
6Back to top Go down   anyone used these? Empty Re: anyone used these? Mon Dec 16, 2013 12:32 am
If you're in the US you can get a good deal on Magnecor leads these days.  The price has gone up a bit but in August I bought a 2V K100 set for $51.30.  I bought some K75 ones and K11 ones too.  With shipping the total for all three sets was $155.
http://www.amazon.com/dp/B0057GEUWG/ref=pe_385040_30332200_pe_309540_26725410_item
I've been running them in two of my K1100s and one K75 for several years now and they work fine.
7Back to top Go down   anyone used these? Empty Re: anyone used these? Mon Dec 16, 2013 1:21 am
andyb
andyb
I'm using them on the K100RT, been on there a few years now, no problems at all and definitely cheaper!!!
Merry Xmas Rossko and family!
jump in the car with Klompy!
AndyB
'03 K1200GT,
'88 K100 RT
Chassis number: 0097248 ; Vehicle code: 0504; Series: K589
Model: K100RT 84 (0504 (0505) Body Type: K100RT 84 (0504)
Catalog Model: ECE; Engine: (0504); Production: 1988/9
anyone used these? 13763011
8Back to top Go down   anyone used these? Empty Re: anyone used these? Mon Dec 16, 2013 2:07 am
You can buy NGK 5K ohm caps for less than five dollars a piece, then access 7 or 8mm silicone leads of the right lengths for another several dollars each from an auto part supply house - remember not to use resisted caps on any K1100 because the sparkies should be resisted already - and for less than fifty dollars you've got a set of leads that you made yourveryownbadself. Mine are blue. I think Blakey's are red.
9Back to top Go down   anyone used these? Empty Re: anyone used these? Mon Dec 16, 2013 2:33 am
Yep, I got the red ones...from Realm. No problems whatsoever.
10Back to top Go down   anyone used these? Empty Re: anyone used these? Mon Dec 16, 2013 2:42 am
I forgot to mention that anything John Rayski from E.M.E. sells is good quality, OEM replacement stuff. I stock a fair few of his Bosch and Enduralast parts as options for those customers not wanting to 'lash out' price-wise for BMW's OEM parts. He does sell some Chinese stuff, but otherwise it's all higher quality, but he'll always spell it out if it's not 'genuine'. His Girl Friday, Jody, always gives good phone, too.
11Back to top Go down   anyone used these? Empty Re: anyone used these? Mon Dec 16, 2013 4:07 am
andyb wrote:I'm using them on the K100RT, been on there a few years now, no problems at all and definitely cheaper!!!
always welcome Rossco but you cannot sing as you couldn't carry a tune in a bucket which as we all know is where ABS units are kept....looking forward to a coffee and raisin toast at Kiama.....mmmmm
12Back to top Go down   anyone used these? Empty Re: anyone used these? Mon Dec 16, 2013 7:54 am
Two Wheels Better wrote:- remember not to use resisted caps on any K1100 because the sparkies should be resisted already -
It's correct that K11's using resistor spark plugs.
But the genuine cables have also a 5 Kohm resistor in the cap, and a 1 Kohm resistor in the coil end.
13Back to top Go down   anyone used these? Empty Re: anyone used these? Mon Dec 16, 2013 9:41 am
thats a lot of resistance compared to 5-6 KOHM on the K100
14Back to top Go down   anyone used these? Empty Re: anyone used these? Mon Dec 16, 2013 10:56 am
Of course, Inge, I should have more clearly written that one should remember not to use resistor plugs in their K100!
"Resistance is futile."
-The Borg
anyone used these? Thebor10
15Back to top Go down   anyone used these? Empty Re: anyone used these? Thu Dec 19, 2013 9:14 pm
Rabidchiwawa007
Rabidchiwawa007
I'm using NGKs on my 4v k100.  The first cylinder plug really likes to pop off sometimes, mostly on startup.  So much to the point that I cut a piece of wood and jammed it in there so it can't pop off.  Other than that, I like them much better than the stock metal caps.
1968 BSA Lightning
