1Back to top Go down   86 K100RS from Hong Kong Empty 86 K100RS from Hong Kong Fri Nov 01, 2013 1:14 pm
billy_k100
billy_k100
Hi,
I am going to restore my 1986 K100RS. It needs a new clutch, and the output shaft seems need replacing or repairing as well. So i want to get some information from here.
2Back to top Go down   86 K100RS from Hong Kong Empty Re: 86 K100RS from Hong Kong Fri Nov 01, 2013 1:56 pm
MikeP
MikeP
Welcome Billy.
You should be able to find all the information and help you'll need here.
1992 K1
3Back to top Go down   86 K100RS from Hong Kong Empty Re: 86 K100RS from Hong Kong Fri Nov 01, 2013 2:02 pm
billy_k100
billy_k100
MikeP wrote:Welcome Billy.
Thanks does it mean i can post now?
My urgent problem is that, according to motorworks' data check, my bike should have originally fitted with 6 rivet output shaft assembly. Can I upgrade to 12 rivet? What modification do i need?
4Back to top Go down   86 K100RS from Hong Kong Empty Re: 86 K100RS from Hong Kong Fri Nov 01, 2013 2:11 pm
MikeP
MikeP
Ask in the relevant section. Have a quick search first, you'll probably find many of you questions have been answered over the years.
1992 K1
5Back to top Go down   86 K100RS from Hong Kong Empty Re: 86 K100RS from Hong Kong Fri Nov 01, 2013 2:18 pm
hi billy ...welcome to the forum
the second question should be posted in the
 https://www.k100-forum.com/f10-engine-and-transmission
have fun
6Back to top Go down   86 K100RS from Hong Kong Empty Re: 86 K100RS from Hong Kong Fri Nov 01, 2013 2:24 pm
Find a used one from a K1100. No mods required.
7Back to top Go down   86 K100RS from Hong Kong Empty Re: 86 K100RS from Hong Kong Sat Nov 02, 2013 4:54 am
henkozzy
henkozzy
Hoi Billy
Welcome and good luck with your repair    Very Happy
8Back to top Go down   86 K100RS from Hong Kong Empty Re: 86 K100RS from Hong Kong Sat Nov 02, 2013 6:11 am
BIG D
BIG D
Cool
Hi Billy welcome to the forum mate.
BIG D
9Back to top Go down   86 K100RS from Hong Kong Empty Re: 86 K100RS from Hong Kong Sat Nov 02, 2013 10:42 am
Ghost who rides
Ghost who rides
Hi Billy welcome to the forum, this is the best place to get advice, in English language that is.
You say you need a new clutch, how many Kms has the bike? Hong Kong is probably hard on clutches
but they are usually reliable for 2 - 3 hundred thousand Kms. Give this information and the experts here will advise.
The 6 rivet output shaft is only a problem if it is showing signs ie. noisy. Are you sure it needs doing?
10Back to top Go down   86 K100RS from Hong Kong Empty Re: 86 K100RS from Hong Kong Sat Nov 02, 2013 12:04 pm
Beemer Wheeler
Beemer Wheeler
Welcome Billy !
Good luck on the repair.
1986 K 100 RT "K-T" short for "Katie" 120.000 Km
   86 K100RS from Hong Kong 2cr0y2r  86 K100RS from Hong Kong 116p8ic
1998 BMW 318i Cabrio
2012 Yamaha YFL 381 (Flute)
2005 Yamaha PSR E-203 (Keyboard Synth).
2012 Yamaha 7 HP outboard engine
"Beemer Wheeler" Certified Brick Aviator since July 2013
Ham radio call sign HA5AH
http://h2fuel.mobi
11Back to top Go down   86 K100RS from Hong Kong Empty Re: 86 K100RS from Hong Kong Sat Nov 09, 2013 4:56 pm
Hi Billy,
Good to have you with us and as the guys say pop a post in the relevant technical section and you are sure to get responses.
