1Back to top Go down   New member Empty New member Tue Nov 05, 2013 1:31 pm
Mike101
Mike101
Hello all,
     I'm the new owner of a 1987 K100 LT in gold and not beige as it says in the V5.
One of you on here already know me but hello to the rest of you.
Only had the bike just over a week and already done 500 miles.  I use it for my work hack as my other bike is a Yamaha Tenere and i want to keep that for getting muddy.
So far the bike is great apart from a very heavy throttle which i must get sorted and a clutch that seems to get heavier while the engine is running.
I'm based near Salisbury so wave if you see me.
Mike
2Back to top Go down   New member Empty Re: New member Tue Nov 05, 2013 2:07 pm
welcome aboard mike
hope you enjoy that ride .and get on top of those small maintenance issues
3Back to top Go down   New member Empty Re: New member Tue Nov 05, 2013 2:08 pm
aeronut7
aeronut7
hi mate...my throttle is also a bit hard to operate...ive been told not to put oil in the cable though
as it was not designed to be oiled....not sure about that though...
welcome to the site theres lots of great info on here...
4Back to top Go down   New member Empty Re: New member Tue Nov 05, 2013 3:29 pm
moose97
moose97
Welcome!
1985 BMW k100 rt
5Back to top Go down   New member Empty Re: New member Tue Nov 05, 2013 3:53 pm
MikeP
MikeP
New member 177912
Heavy throttle?
I've had MoT testers add that as an advisory for years even when I point out that there's a screw to adjust the throttle action and I like it heavy (so that it doesn't close without positively being closed by me).
Have a look under the handlebar assembly for a big aluminium screw:
New member K75S%20%2886%29-L
New member K75S%20%2885%29-L
They don't all have them but it may be the cause.
A "positive close" throttle may also save you going through all the disconnecting your TPS malarkey too.
1992 K1
6Back to top Go down   New member Empty Re: New member Tue Nov 05, 2013 4:21 pm
BIG D
BIG D
Cool
Hi Mike, welcome to the forum mate how's Pats old K then she's a good one, lots of info on this site enjoy.
BIG D
7Back to top Go down   New member Empty Re: New member Tue Nov 05, 2013 4:47 pm
the.postman
Welcome mike101
And for those without the "big ally screw, cruise control"
give this area a good clean and v.light re-grease
New member Throtl10
1984 srx 600
1986 cbr1000f/h
8Back to top Go down   New member Empty Re: New member Tue Nov 05, 2013 5:50 pm
Englishkent
Englishkent
I was slightly disapointed mine said beige in the log book.... Much prefere Bahama Bronze (although that sounds like a sun tan lotion).
9Back to top Go down   New member Empty Re: New member Tue Nov 05, 2013 5:55 pm
henkozzy
henkozzy
welcome Mike
10Back to top Go down   New member Empty Re: New member Wed Nov 06, 2013 12:11 am
aeronut7 wrote:hi mate...my throttle is also a bit hard to operate...ive been told not to put oil in the cable though
One thing I have found is that the rubber grip can work itself up against the switch block and that will cause the throttle to become stiff and sometimes it is as simple as when tou hold the grip that can exert enough pressure to make it tight but only when riding which makes for a good mystery.
11Back to top Go down   New member Empty Re: New member Wed Nov 06, 2013 2:15 am
Take the cover off (and brake master if you're industrious,) clean all of the old grease out and hose it down with silicone lubricant.  Having tried all sorts of stuff over the years, that's the only thing that I've found that will make a 2V throttle cable return well.
12Back to top Go down   New member Empty Re: New member Wed Nov 06, 2013 8:14 am
Mike101
Mike101
BIG D wrote:Cool
BIG D
HI,
   So you know me form the 'other' place then.  Yes Pats K is very nice indeed.  Since i got it i have jumped on it and ridden it in all weathers without any issue.
I am really enjoying the fairing and compared to the Tenere i love the seat.  But one thing i wasn't expecting is i am getting a bit of wrist and shoulder ache on long trips..i never got those on the Tenere but my backside would die first.
Mike
13Back to top Go down   New member Empty Re: New member Thu Nov 07, 2013 3:31 am
krambo
krambo
Welcome to the site Mike Wink
"Aut viam inveniam aut faciam." New member Uk-bmw12
http://www.its-personal.net
14Back to top Go down   New member Empty Re: New member Thu Nov 07, 2013 10:08 am
Mike101
Mike101
MikeP wrote:New member 177912
Heavy throttle?
I've looked and i don't have that screw and spring nor anywhere to fit it.  Any ideas?
Mike
15Back to top Go down   New member Empty Re: New member Thu Nov 07, 2013 10:15 am
MikeP
MikeP
Mike,
Look under the housing and you'll see a white plastic blanking plug. It just hooks out revealing the thread and the point where the bush in the end of the screw makes contact.
1992 K1
16Back to top Go down   New member Empty Re: New member Thu Nov 07, 2013 12:36 pm
Mike101
Mike101
MikeP wrote:Mike,
HI,
   just been and looked again and i don't have this screw or blanking plate.
Mike
17Back to top Go down   New member Empty Re: New member Thu Nov 07, 2013 1:28 pm
Not all of the Ks had it and I have never worked out which ones did and didn't but there is a place to make a thread if you really want to do it.
18Back to top Go down   New member Empty Re: New member Thu Nov 07, 2013 2:38 pm
MikeP
MikeP
The only K's I've seen without are the 16v models which need a different upper housing and the big aluminium damping screw:
New member K1%20BMW%20%28120%29-M
Even Boxers as far back as the /7 models all had the capacity to fit the screw.
Locate the hole that the bar mounted mirror goes through. There will be a recess between that and the main body of the throttle assembly. The blanking plug is recesses, you may need a torch and look directly into the recess to spot the plug.
1992 K1
19Back to top Go down   New member Empty Re: New member Thu Nov 07, 2013 4:36 pm
k-rider
k-rider
welcome to the forum and congratulations on your ^new^bike:D
k-rider
20Back to top Go down   New member Empty Re: New member Thu Nov 07, 2013 7:53 pm
Here's one with and one without!
 New member Sam_0716
Unfortunately, as these were e-bay items, I don't know from which models they originated.
BTW, welcome, Mike101,
21Back to top Go down   New member Empty Re: New member Thu Nov 07, 2013 8:25 pm
Comberjohn
Comberjohn
My '84 RT doesn't have the blanking plug, unfortunately. Had it on my LT and it was useful.
Has anyone drilled and tapped a switch unit and what drill size and tap did you use?
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
22Back to top Go down   New member Empty Re: New member Thu Nov 07, 2013 8:50 pm
Hi John,
To use the BMW screw the thread is an extra fine series, M8 x .75, so the tapping drill would be 7.3 mm.
Pity it's not a common size.
Cheers,
23Back to top Go down   New member Empty Re: New member Thu Nov 07, 2013 8:58 pm
Another option in that hole is the "Flip-a-Lever" which allows you to turn the throttle friction on and off.
New member DCP_0383
24Back to top Go down   New member Empty Re: New member Thu Nov 07, 2013 9:40 pm
Comberjohn
Comberjohn
Was looking for a 'Flip-a-Lever' but they seem to be hard to get and/or expensive.
Place in the States has them for $57 and one in Australia for $99! By the time you add p&p...
Looking on eBay I reckon Paul's idea of drilling and tapping could be done for about £20($30) including the friction screw.
Another little job for when it snows over the winter.
2010 VFR 1200F DCT
2010 R1200GS(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
25Back to top Go down   New member Empty Re: New member Thu Nov 07, 2013 11:31 pm
MikeP wrote:The only K's I've seen without are the 16v models which need a different upper housing and the big aluminium damping screw:
My K100 never had anything but a flat area which was part of the casting, no hole no plug just a place to put it.
I have a friend with a K75C and it has no hole.
The throttle locks are not legal in Australia and most bikes nowdays dont have them.
26Back to top Go down   New member Empty Re: New member Fri Nov 08, 2013 8:54 am
MikeP
MikeP
Rick,
I'm not saying that all bikes had the capacity, just that I've never seen one without (that includes all the ones we were supplied with at work).
1992 K1
27Back to top Go down   New member Empty Re: New member Fri Nov 08, 2013 9:47 am
I did sound a bit defensive but I didn't mean it that way.
The throttle lock thing became a bit of an issue in Australia for a while (between the states until the federal government made some design rules about it to cover all states) and BMW probably just said go get your own we don't want anything to do with it.
